Go Back   Automotive Forums Car Chat > Fabrication & Tools > Fabrication Tools
Fabrication Tools Discuss and learn about all types of tools used in fabrication, from angle grinders to english wheels.
Old 05-31-2006, 01:00 PM
TheSilentChamber's Avatar
TheSilentChamber TheSilentChamber is offline
Forunn Daberator
Shot peening in a blasting cabnet?
I'v heard though a few places that you can use a blasting cabinet to do shot peening, just have to change the medium and maby the tip to accomidate it. Anyone know anything about this? I know the basic ideas follow the same principle, but know if this setup would work, or what pressure it would need to be at.
Old 05-31-2006, 05:08 PM
mike@af's Avatar
mike@af mike@af is offline
Captain Over Engineer
Re: Shot peening in a blasting cabnet?
What's shot peening?
-Mike
Old 05-31-2006, 06:35 PM
Forunn Daberator
http://en.wikipedia.org/wiki/Shot_peening
http://en.wikipedia.org/wiki/Peening
It helps relieve stress and hardens the surface of the metal.
Old 05-31-2006, 07:22 PM
mike@af's Avatar
I dont see why a blast cabinent wouldnt work. Basically all you're doing is shrinking the material by making it thicker. I think the only things to worry about are the feed hose/gun, and the window. A peen on that glass viewing window and its a new ligement on your face.
-Mike
Old 11-20-2006, 08:00 PM
SaabJohan SaabJohan is offline
Actually peening introduces a compressive stress in the surface, this can prevent fatigue in high stress areas.
http://www.metalimprovement.com/shot_peening.php
Usually special equipment is needed.
There are essientially two types of peening machines; centrifugal and pneumatic. The basic principles of the pneumatic machine is similar to blasters, but the actual machine is much more complicated.
CNC Shot peening machine
Shot peening machine for crankshafts
A peening machine in action
http://www.webtraxs.com/dlcount.php?...tary lance.wmv
Old 05-05-2019, 05:05 PM
Schurkey Schurkey is offline
Shot PEENING and shot BLASTING are entirely different processes for entirely different end-results.
Shot peening is a surface treatment that increases fatigue life. It requires special tooling, and is NOT something done at home or even by a small business. This is a serious metal-working process, with aerospace applications--and aerospace quality assurance.
Shot blasting is a surface-cleaning method. Lots of automotive machine shops use a shot-blasting cabinet. The shot knocks the carbon and rust off the casting. Nothing special about it--you load parts into a rotisserie, the machine throws the shot at the part using a centrifugal "pump", and the shot pounds the carbon and rust into dust. If you're smart, you protect the machined surfaces of the casting--the lifter bores, the crank journals, that sort of thing.
I would not expect a normal sandblasting or glass-beading cabinet to accept the steel shot used in shot blasting.
For the good of the Free World, DEMAND COMPENSATION FROM CHINA for their release of the Virus Originating in the Wuhan Laboratory, released (intentionally or negligently) into the world in 2019 (VOWL-19). Ten trillion to start with, increasing as needed from there, PLUS compensation for the sickened, and "wrongful death" settlements for the families of those who didn't survive. END trade with Communist China.
