Go Back   Automotive Forums Car Chat > Mazda > RX-7
Old 05-31-2006, 10:22 AM
ude_loose's Avatar
ude_loose ude_loose is offline
Send a message via Yahoo to ude_loose
87 RX-7 Problem
Well when i first got my 87 RX-7 N/A the guy that I bought it from told me that when the engine warms up it sometimes start running rough. But I still bought it ($800 yes it was a bet), what it did when it warmed up was like if it wanted to turn off and when put in gear and wanted to take off it would take off really slow because even with the gas pedal all the way down it would still not go like normal but really slow I would just let it sit for acouple seconds and the engine will go back to normal. I did the tune up spark plugs, cables, oil, oil filter, and air filter and I also bought a fuel injector cleaner and it did not do that anymore the car was now perfect. But just yesterday about a month of driving the car daily with no problems it started doing that again but only when it warms up and sometime if turns off or if I turn it off it has a hard time starting until it cools down for about five minutes and then it is good to go again. I checked the oil and it is full, I was wondering if it is because my straight pipe exhaust is ripped by the cat converter or if i need to change the fuel filter. Well I really have no idea why it does this someone please help me why does it do this?
Old 05-31-2006, 12:36 PM
ghostrx7's Avatar
ghostrx7 ghostrx7 is offline
Send a message via AIM to ghostrx7 Send a message via Yahoo to ghostrx7
Re: 87 RX-7 Problem
could b a leaky injector, or a manifold leak......its hard to start a hot rx after gas leaks in there....not really sure tho..
88 10th anniversary rx7 and company h2.
[IMG][/IMG] [IMG]
atkins streetported 3mm seal engine, act clutch, lightweight flywheel, downpipe, straightpipe, greddy power extreme exhaust, hks ssqv blow off valve, short shifter, tein flex suspension, energy bushings, bonez intake, new brakes, rotors, toyo tires, mazdaspeed replica seats
Old 06-01-2006, 10:57 AM
ude_loose's Avatar
Re: 87 RX-7 Problem
I also noticed then when I try to turn it on again alot of smoke comes out the muffler...
Old 06-01-2006, 12:07 PM
mwolvin mwolvin is offline
Re: 87 RX-7 Problem
What color smoke?
Old 06-01-2006, 11:06 PM
ude_loose's Avatar
Re: 87 RX-7 Problem
white
ude_loose's Avatar
Re: 87 RX-7 Problem
Originally Posted by mwolvin
What color smoke?
white...
Old 06-02-2006, 02:38 AM
fb33112arx7 fb33112arx7 is offline
Re: 87 RX-7 Problem
It could be too much unburnt gas going through the engine and collecting and burning in the cat that is causing the white smoke upon start-up.
Old 06-02-2006, 10:26 AM
ude_loose's Avatar
Re: 87 RX-7 Problem
So what will be the problem the cat converter or the fuel pump?
Old 06-02-2006, 12:38 PM
drftk1d's Avatar
drftk1d drftk1d is offline
boost in, apex seals out
Send a message via AIM to drftk1d
Re: 87 RX-7 Problem
yeah hot start problems are common among the S4's
RX-7 TII
Re: 87 RX-7 Problem
More likely the fuel injectors are leaking. Try this.. Start the car and let it warm up. Then shut it down, and after letting the car cool enough to not burn yourself, pull out some of the spark plugs. You are looking for signs of excess gas or any water.
Old 06-03-2006, 09:11 PM
ude_loose's Avatar
Re: 87 RX-7 Problem
well here are the updates, I have also noticed that when it stats to do all this it like shakes and then white smoke comes out of the middle of the car by were the cat converter is and at the end of the exhaust pipe the smoke comes out brownish. Today we changed the fuel filter and it stil had the same problem checked the fuel pump and it still did it im gettin a pretty good sparg and their seems to be no water or gas in the spark plug could the problem be the cat converter of too much unburnt gas collecting their because when the car starts to do this it smells like unburnt gas.. or could it be some kind of sensor.....Some one please Help Me Out...
Old 06-04-2006, 09:38 PM
drftk1d's Avatar
Re: 87 RX-7 Problem
check the cat then
if at all possible take it off and see how it runs
(cover your ears too :P)
RX-7 TII
Old 06-04-2006, 10:40 PM
ude_loose's Avatar
Re: 87 RX-7 Problem
alright well if it is the cat that their is too much unburnt gas collecting their why is that how can i fix it...what if i hook up the computer to the car is it possible to get any codes....
Old 06-05-2006, 09:31 PM
fcdriver fcdriver is offline
Re: 87 RX-7 Problem
Unless it's throwing a check engine light then you won't be able to pull any codes from it. If the cat is stopped up then replace it with a new one. If that still isn't the problem then look at the injectors possibly leaking.
Originally Posted by dampachi
Violence isn't always the answer..but sometimes..depending on the question..it can be the answer.
Old 06-06-2006, 10:05 AM
ude_loose's Avatar
Re: 87 RX-7 Problem
But if the injectors were to be leaking wouldnt the car not stop doing the shaking what so ever because mines does stop for a while...
