Old 05-31-2006, 09:45 AM
kengot kengot is offline
Check engine light-need advice
My son has a 2001 Durango with two trouble codes showing; P0141/P0161, which are Sensor Heater Circuit malfunction bank 1, sensor 2 and bank 2, sensor 2. I cleared the codes from the computer and they came back on within one week.
Is there something I should check which may be triggering the codes, or should I change both sensors?
Thanks
Old 05-31-2006, 12:58 PM
UncleBob UncleBob is offline
AF -Advisor
Re: Check engine light-need advice
Thanks
if its a CA model, there is a relay in the power distribution box that controls the heater circuit, and also a fuse. Simply, you need to verify power and ground to the heater circuit at the O2's, and follow the power until you find the problem.
Since you have 2 O2 heater codes, there is probably a problem leading upto the O2's, BUT, what could have caused that problem is a shorted heater circuit in ONE of the O2's....so you need to also check for resistance on the O2's.
life begins at 10psi of boost
Three turbo'd motorcycles and counting.
Old 05-31-2006, 01:25 PM
curtis73's Avatar
curtis73 curtis73 is offline
Professional Ninja Killer
Excellent advice ^^^ ditto
Dragging people kicking and screaming into the enlightenment.
