Go Back   Automotive Forums Car Chat > Mazda > MPV
Old 07-28-2002, 11:45 PM
fossilfuel fossilfuel is offline
92 mpv
I'm looking at a 92 MPV. I saw in another post that the transmission may be troublesome for these vehicles. What else should I be wary of? It is a 4wd with 103,xxx miles.
Old 11-14-2003, 03:43 PM
chuy22 chuy22 is offline
Re: 92 mpv
I had a 92 and got 260,000 from the original engine and transmission. You be wary of the engine clicking noice. The lifters click on those engines alot and over time become real loud. You will need a head job for the engine. Also there is a oil seal on the rear of the engine by the fire wall. This seals tends to leak alot and to fix this problem is very costly.
Old 01-29-2004, 09:43 AM
1993 MPV 1993 MPV is offline
What Is This Oil Leak You Are Talking About?
Thanks
Old 02-17-2005, 06:29 PM
Doc_Ratchet's Avatar
Doc_Ratchet Doc_Ratchet is offline
Send a message via AIM to Doc_Ratchet
Re: 92 mpv
Couple other things to be wary of are the thermostat, water pump, and heater core, all of which are serious pains in the backside to work on. First time in my life I've ever seen a two part thermostat housing and a lower engine/bottom radiator hose mount for same.
About the Tacuma MPV... Euro19 Tacuma 6 10-19-2008 03:53 PM
mpv power mods! fatninja19 MPV 6 10-30-2004 08:25 AM
The most beautifull and luxurious MPV (little minivan) ever Euro19 Tacuma 12 03-03-2003 04:49 PM
1994 MPV Blueprints psonefreak MPV 0 01-17-2003 11:45 PM
MPV Heater blows little heat Treebrand General Discussion 0 03-02-2002 06:50 PM
