Old 05-30-2006, 09:43 PM
jetranger_2000 jetranger_2000 is offline
1991 escort 1.9 wont start
new guy here!
My escort wont start
when I try to turn over I have power to the "dinger" all the lights work but there is no start
I tried to boost battery and nothing.
I can hear the fuel pump.
tried to go from positive to starter relay nothing
when I go to start it I get the fuel cut off light come on. checked the button in the trunk and it was in the down position
just get ckick sound
thanks for any help
Old 05-31-2006, 03:29 PM
jeffescortlx jeffescortlx is offline
Send a message via AIM to jeffescortlx
Re: 1991 escort 1.9 wont start
I would be it's the main ground to the engine/tranny.
I make slow Escorts less-slow.
My cardomain
Old 06-04-2006, 11:31 AM
mightymoose_22's Avatar
mightymoose_22 mightymoose_22 is offline
Your starter is probably either bad or stuck.
When you try to turn it over, try the good ol' start with headlight turned on.... see if you really have enough power.
If maybe the starter is stuck, put the car in gear and roll it a couple feet then try again.
The starter comes off pretty easily... you can take it off and bench test it.
Old 06-05-2006, 10:55 AM
junk yard doggie's Avatar
junk yard doggie junk yard doggie is offline
Yes it could be the starter, tap on it with a hammer. If it is sticking that will usually free it up. Have you checked for spark? could be the ignition module as well.
Mike
Old 06-07-2006, 04:24 AM
AzTumbleweed's Avatar
AzTumbleweed AzTumbleweed is offline
Clutch Safety Switch is what I'd check first. The fuel cut-off light is supposed to come on in the start position. That's the only way you know if it works.
Old 06-09-2006, 09:28 PM
No... you wouldn'[t even get the click if it was the clutch switch... power is getting to the starter, it just isn't turning. It's either stuck or not enough juice in the battery.
Old 06-10-2006, 12:59 PM
My mistake. Reread your post where it said you are getting a click sound. I'll bet your battery is bad. If a battery is really messed up a jump start won't even help.
