Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 05-30-2006, 09:28 PM
xavier3jr's Avatar
xavier3jr xavier3jr is offline
Send a message via AIM to xavier3jr Send a message via MSN to xavier3jr
rebuilding head
well David's geting to me trying to get further up on me so i've got some money saved up so here goes tell me if im missing anything because im giveing it to the guy tommrow.
3 angle vaulve job- or 5 whitch should i do the guy says i should do 5
new vaulves
port and polish
shaved head
new vauvle guide seals
new rockers
new retainers
cams- but what should i go with
cam gears
also geting tb ported to 55 mm and getsing my header and intake manni bored to match the head. please give me any more sugestions.
oh and the port and polish and vaulve job and shaved head is only costing me $250 :-D damn its good to know people
96 GS - 5 Speed-Sold
1998 Ford F-150 XLT 4X4
Old 05-30-2006, 09:56 PM
blk_srt's Avatar
blk_srt blk_srt is offline
Send a message via AIM to blk_srt Send a message via MSN to blk_srt
Re: rebuilding head
Are you planing on boosting in the future? If so shaving isnt a good idea unless you replace the head in the future. 5 angle is the way to go. Comp cams are good just get the ones that match your goals
2004 Flame Red SRT-4
|Audiobahn 1200Q|Rockford 602s|Jensen flip out dvd|
Mods:
Old 05-30-2006, 10:06 PM
xavier3jr's Avatar
Re: rebuilding head
i know but its proably gana be a while before i can turbo it so im not gana shave it much. and when i finaly do turbo it ill just put a thick head gasket on it.
Old 05-30-2006, 10:08 PM
blk_srt's Avatar
Re: rebuilding head
sounds good then
Mods:
Old 05-31-2006, 12:22 AM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
Re: rebuilding head
Yeah, I'm evil . I'm sending off my TB tomorrow morning to get ported and powdercoated. Then sending off the head in a week or 2. Should be sweet!
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Old 05-31-2006, 02:09 AM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
Re: rebuilding head
Travis, read this article on choosing the right cams. It's very important to choose the right ones, otherwise you won't get the gains out of them that you're looking for.
http://dsmtuners.com/forums/showthread.php?t=221200
95 Talon TSI AWD
97 Eclipse GST
Old 05-31-2006, 11:06 AM
blk_srt's Avatar
Re: rebuilding head
Lot of good info there
Mods:
Old 05-31-2006, 10:21 PM
xavier3jr's Avatar
Re: rebuilding head
well i got everything out today the vaulves and all and i went ahead and tore the block apart. theres just one question about the block. on the bottom pully can u just use any pully puller to get it or do uhave to have the special chyrysler puller. but anyways im giveing the guy the head tommrow for the port and polish and 5 angle vaulve job. wish me luck lol
Old 05-31-2006, 10:29 PM
scottsee scottsee is offline
Send a message via AIM to scottsee
Re: rebuilding head
Remember, you should always use new lifters with new cams. I personaly plan on using a 50trim or simular wich will be fine on a fresh/stock 1g head with comp2 cams. Reamber that your head will reqire an RA-20 finish for any metal MLS gasket or RA-30 finish for Cometic or HKS gasket. Unless your refinishing your deck keep into consideration its very diffucult to get metal gaskets to seal on old unfinished decks without alot of prepwork. I'm going over to a friends garage tonight for the same reasion. He had an RA-20 finish done on his head, tryed to refinish his deck but couldn't get it smooth enought to use a metal gasket. So were taking off his MLS gasket and putting a stock gasket on.
Old 06-01-2006, 01:58 AM
Re: rebuilding head
Hes just rebuilding the 420a so there isn't much of a need for those special gaskets.
As for the pulley Travis, I just use whatever the hell puller that we have laying around at the time, it doesn't have to be the special one from the factory.
95 Talon TSI AWD
97 Eclipse GST
Old 06-01-2006, 02:49 AM
Thor06's Avatar
Thor06 Thor06 is offline
Jizzed In My Pants
Re: rebuilding head
I think it would be pointless to replace the rockers and lifters on it. I had a thread on this a while ago. The lifters dont even touch the cams so why does it matter if they are new or not? Also the rockers are rollers rockers (I think they are on the 420a anyway) so they dont hardly wear at all.
Build on hold until I get a good paying job, either in school or once I get out. At that time a full tear down and complete rebuild should be in order.
The Purple People Eater will ride again... January 2011 can't come soon enough.
Old 06-01-2006, 06:32 AM
defiancy's Avatar
defiancy defiancy is offline
Stay classy San Diego
Re: rebuilding head
If you are putting on aftermarket cams, you definately want to change the rockers and the springs.
The springs on your head and 1g heads are going to be set to the stock cam lope.
IE: The spring compresses and decompresses as the cam turns, when you put bigger cams in there you need a spring that will equally match the the cams. Or the spring will be compressed all the way before the cam is fully turned.
1991 GSX 2.3 Stroker
Old 06-01-2006, 10:58 AM
Thor06's Avatar
Jizzed In My Pants
Re: rebuilding head
http://www.automotiveforums.com/vbul...d.php?t=553633 Read through there, E-Klips and Kevin say its not a big deal.
Old 06-01-2006, 06:35 PM
defiancy's Avatar
Re: rebuilding head
Just telling you what I learned from my shop which builds dsm race cars.
I know that they will function fine without replacing those items. But If you do replace them it will perform better.
Old 06-01-2006, 08:38 PM
xavier3jr's Avatar
Re: rebuilding head
i am puting EVERYTHING new. from top to bottom is gana be new mabey more money but oh well. my motor my money i want it to be perfect
