Old 05-30-2006, 08:58 PM
Camaro84 Camaro84 is offline
Car Wont turn over!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
my car wont turn over any more!!!!!!!!!!!!!!! its an 84 with a 350 brand new.......... i was driving it for about two hours the other day and parked it fine in front of my house........cam e back out two hours later and now it wont evn turn over im getting power to the big terminal on my starter but there is no power goin to the other wire on the smaller terminal to the right..............i tried it with the ignition on also!!!!!!!!!!!!!
but i did notice when i looked at the starter the first time the smaller terminal wire was really loose almost to the point were it could be pulled off...... i thought i found the problem so i tightend it thinking the problem was fixed................but it wasnt................
so basically i was wondering if maybe i burnt up my starter while i was driving and thats why it wont turn over????????????
but i really dont know what do you guys think???????????????
Old 05-30-2006, 09:07 PM
Rally Sport's Avatar
Rally Sport Rally Sport is offline
Is eating.
Send a message via AIM to Rally Sport Send a message via MSN to Rally Sport
Re: Car Wont turn over!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
What does it sound like? Is it a click when you turn your key? Or is it the usual cranking noise.?
Old 05-30-2006, 09:08 PM
ummmmmmmmmm its not making any kind of noise....................
Old 05-30-2006, 09:12 PM
Is eating.
OKay when your turn your key to start it up does it make a click noise? or does it crank but not roll over?
Old 05-30-2006, 10:35 PM
it doesnt make any kind of noise............all that happens is that the gauges jump and my radio turns off...........
Old 05-30-2006, 11:03 PM
malletslinger's Avatar
malletslinger malletslinger is offline
Did you check your fuses?
Old 05-30-2006, 11:58 PM
Thast what i was thinking that maybe it could be one of my fuses because my rear hatch wont open from the inside compartment but i checked all the fuses that i can see if are broken and they all looked fine.............. i dont know about the big metal fuses.............
Old 05-31-2006, 09:12 AM
wrightz28's Avatar
wrightz28 wrightz28 is offline
is bring'n sexy back
You're talking about the purple wire on the 's' terminal right? That's the ignition switch feed that sends 12v to the solenoid when the key is turned to start/run. If you've verified you do not have the 12v on it with the key turned then you need to trace back to the switch for a broken wire/bad switch or no power to the switch.
Old 05-31-2006, 02:04 PM
There should be a fuse just for the hatch, but the switch may be bad.
Old 05-31-2006, 04:42 PM
well the purple wire is not purple anymore does any one have any picture of a starter i could look at........ but i no its the wire thats by itself and the other wires that are on the bigger terminal have power so yeah were does that wire go ...... it looks like it goes into the fire wall how am i gonna trace that????????????????..................
Old 06-01-2006, 08:58 AM
wrightz28's Avatar
It goes to the ignition switch as stated. The actuating rod may not be pushing the switch all the way to the start position or the swithc is not getting power or is bad.
Old 06-01-2006, 11:58 AM
bobss396's Avatar
bobss396 bobss396 is offline
Send a message via AIM to bobss396
The car was apart for a new engine? The starter may have gotten dropped or something else may have happened to it. Can you jump it with a screwdriver between the big lug and the S terminal on the solenoid? That would rule out the starter. Also look at the fusible link that comes off the solenoid up the firewall. It will feel like silly putty if the link is blown.
Bob
Old 06-01-2006, 06:03 PM
so i should follow the wire from my solenoid to the ignition swith and make sure there is nothing wrong between the two and check the fusible link......
and somone told me i should check my neutral safty switch.......... but i dont no were to find it..............
and how exactly do i jump the starter......... and what will that determine?????????????????????????
Old 06-01-2006, 06:16 PM
2.2 Straight six's Avatar
2.2 Straight six 2.2 Straight six is offline
That thing got a Hemi?
Send a message via AIM to 2.2 Straight six Send a message via MSN to 2.2 Straight six
the battery ok?
Seatbelts Saved My Life
Old 06-01-2006, 06:52 PM
the battery is good.............
