Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 05-30-2006, 07:41 PM
NateS's Avatar
NateS NateS is offline
Send a message via AIM to NateS
installing 650cc injectors...questions
Okay, so I finally came up with the extra money for a fuel pressure regulator. I will be ordering my fuel pressure regulator within the next week. First question, what is a good pressure to set the fuel pressure regulator at? Now, I heard it is a good idea to replace the lower injector seals. I was planning on ordering them off of slowboyracing.com. After I install the injectors and fpr I will obviously need a bit of a tune. I know you all are just going send me to the faq and dsmtuners.com links but, I wanted to ask anyway. Can anyone give me a good starting point for adjusting the S-AFC with 650cc injectors? Would I be okay setting my afc running 16psi(currently) even though I plan to bump the boost up a bit? Should I tune at the psi that I plan on running or does it not matter? I know I have tons of reading to do on tuning using the AFC but, it would be cool to get an idea where to start or any tips/tricks you all know. I do have a logger so I will using this while tuning. Thanks for any help.
95 GSX 5 speed
2.3L stroker bored .020 over
Built head
Bullseye/Borg Warner T04B 57 Trim Turbo
RNR 3" turboback w/ o2 eliminator
255 lph Extreme Motorsports fuel pump
Extreme Motorsports mbc
SAFC
Greddy Type S BOV
FMIC (core 28x10.5x3.5)
FIC 650cc fuel injectors
RK Sport Fuel Pressure Regulator
My Car Domain
Old 05-30-2006, 08:00 PM
blk_srt's Avatar
blk_srt blk_srt is offline
Send a message via AIM to blk_srt Send a message via MSN to blk_srt
Re: installing 650cc injectors...questions
IIRC base fuel pressure is 43.7psi lower injector seals are a great idea and what are you doing with your stockers?
2004 Flame Red SRT-4
|Audiobahn 1200Q|Rockford 602s|Jensen flip out dvd|
Mods:
Old 05-30-2006, 08:21 PM
NateS's Avatar
Stockers as in my injectors?
95 GSX 5 speed
Built head
SAFC
Greddy Type S BOV
My Car Domain
Old 05-30-2006, 08:29 PM
MexRocket's Avatar
MexRocket MexRocket is offline
yes, he is looking for 450's
STATUS: Near completion for the Engine
PROJECT BEST 1G IN IL:70% Done
MODS: C2 boost,mbc,B16GEGTurbo,12x28x3x3 FMIC,Ported2gmani,k&n.
Being bought in two weeks: Dsmlink,880's,3"exhaust,piping,suspension,axel,dri lled and slotted brakes.
Old 05-30-2006, 09:40 PM
blk_srt's Avatar
yep, perferable to borrow some for a few weeks so I can get dsmlink up and running and then get my 1000ccs
Mods:
Old 05-30-2006, 09:42 PM
xavier3jr's Avatar
xavier3jr xavier3jr is offline
Send a message via AIM to xavier3jr Send a message via MSN to xavier3jr
do non turbo eclipse come with 450's? if so i got a pair u can have
96 GS - 5 Speed-Sold
1998 Ford F-150 XLT 4X4
Old 05-30-2006, 09:49 PM
vanilla gorilla's Avatar
vanilla gorilla vanilla gorilla is offline
No, the non turbo cars didn't come with 450's. I don't know about the 420a but my 4g64 came with 275's. The size should be molded into the injector.
Caleb
vanilla gorilla
'99 Spyder 2.4 5-speed - Red/black,14b,slow
'96 Eclipse GST 5-speed - Paint
www.myspace.com/ballsoutperformance
Old 05-30-2006, 09:54 PM
blk_srt's Avatar
thanks anway. Oh and as far as the afc goes http://www.roadraceengineering.com/newafcsetting.htm there is that and IIRC for 650s set the base tune at -15% and fine tune from there
Mods:
Old 05-30-2006, 10:55 PM
kjewer1 kjewer1 is offline
AF - Advisor
650s are 31% larger than 450s, so -31% would be like "stock."
(450/650)-1
Best thing to do is very that fuel trims after the injector swap and change to 31% or whatever you choose didn't change much. For exmaple, if trims were right on before the swap, you want to set the AFC so trims are right on after the swap. The RRE setup method is worthless as far as tuning goes, IMO, but it's good for setting up the various parameters like throttle sensor type, airmeter type, etc.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 05-31-2006, 02:20 AM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
I think the 420a injectors are probably 100s cause that's about all the power you can make out of the engine.
95 Talon TSI AWD
97 Eclipse GST
Old 05-31-2006, 08:55 AM
NateS's Avatar
Okay so if I'm reading this right I should start by setting the base trims at -31%?
95 GSX 5 speed
Built head
SAFC
Greddy Type S BOV
My Car Domain
Old 05-31-2006, 10:37 AM
That is correct.
95 Talon TSI AWD
97 Eclipse GST
