Go Back   Automotive Forums Car Chat > Nissan > Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35
Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 Excellent platform and the good ol' VQ30DE and VQ35DE engines.
Old 07-28-2002, 10:01 PM
jneidert jneidert is offline
Send a message via AIM to jneidert
Skyline Swap.
Any one ever heard of an r34 motor in a Maxima.... Can it even be done?:smoker2:
Jason..
Old 07-28-2002, 10:27 PM
mtrai760 mtrai760 is offline
Send a message via AIM to mtrai760
No and No, RB26DETT= Rwd, Maxima is FWD, besides that the trannies wouldn't mate up...
5spd VLSD
15.2@92mph
180hp & 193tq
Faster than jOO!
A hunting we will go...
Old 07-28-2002, 10:33 PM
Obviously R34 is rwd. If you got R34 rwd conversion and a R34 tranny, wouldnt it work.
Jason..
Old 07-29-2002, 08:24 PM
Paonessa Paonessa is offline
the only nissan skyline engine swap i heard of that worked was a skyline engine in an s6 audi. Need an all wheel drive and i think he had to remove the a/c.
r 34 is awd
Old 07-29-2002, 08:37 PM
If your gonna go through all that you might as well have MoSpeed import ya an R34, because it would probably be cheaper...
5spd VLSD
15.2@92mph
180hp & 193tq
Faster than jOO!
Old 07-30-2002, 11:22 PM
20th maxstyle 20th maxstyle is offline
Send a message via AIM to 20th maxstyle
You would have to do so many body frame alterations. The R34 is AWD not RWD. The second you take a turn with the RB26DETT, the mid section will twist. The reason Skyline's dominated british touring races was because the frame actually twists to better make contact with the road. The front end goes fallowed by the back end. It has an incredible syspension set up. Have you ever seen a supercharged RB26DETT. YES, a supercharged twin turbo in line six. You could fit the R33 set up in a 98 240sx. It has been done.
One Love,
One Life,
One Finish Line
Alex Adrian Quiroz
Project: MAXSTYLE
Old 07-31-2002, 02:14 AM
AkumaMax's Avatar
AkumaMax AkumaMax is offline
Send a message via AIM to AkumaMax
Yes I've heard of the SCed RB26DETT engine I have a pic of it somewhere on a cd there's been a guy who imported an engine from japan instead of an RB26DETT he took a VQ30DET yes a turbo version of the maxima forgot the name for the car it came out of in japan but it took him about 4mounths to get it put in haven't heard yet of how it sounds, acts, or etc...
Mess With The Max Get Scrapped Like The Rest!
Old 07-31-2002, 02:52 PM
that vq30 engine comes out if an I30t infiniti. they're rare engines. he must have payed damn near $7,000-$10,000. i bet his car shits on everything. If you could find that picture i'd really like to see it.
Old 07-31-2002, 03:36 PM
AkumaMax's Avatar
o noooo the engine i'm sure of it doesn't coe out of an infiniti it's a japanese car like gloria or cerfio one of those two. I'll try and find that picture for you when I saw that picture I almost wet myself.
Old 07-31-2002, 03:39 PM
AkumaMax's Avatar
ahh ha I found the pic. but it doesn't allow me to send it give me ur email addresses and i'll send them to you
Old 07-31-2002, 04:06 PM
It's [email protected]
Old 07-31-2002, 05:12 PM
No no no, the VQ30DET comes in the japanese Q45, and it will not simply bolt into a maxima. That engine is for RWD, and the motor mounts do not mount up. However, the internals are all the same, so if you want to run high boost, you can get a DET motor for around $2000 (good luck finding one though) and use the pistons, cams, intake manifold, etc... pistons will lower the compression down from 10.5.1 to 9.1, much better for high boost, less chance of detonation. You will then have to build a custom turbo kit, or buy one from PRI in CO for $4k, since the piping from the DET won't fit in the Max engine bay.
5spd VLSD
15.2@92mph
180hp & 193tq
Faster than jOO!
Old 07-31-2002, 06:02 PM
the Q45 engine is an 8 cylinder and it's almost a 305 cu. in. it's way too big to fit ithe engine bay of a maxima and it's rwd. .
Old 08-01-2002, 12:26 AM
Sit down kiddies, class is in session...
Yes it is RWD, that's why the block won't fit in the Maxima, however, it's not V8, it's a V6, car's in Japan come with different engine options than here in the good ol' USofA. Sure you can get the V8, but the VQ30DET was also available. It's also called the Cima in Japan, not the Q45. It was also used in certain versions of the Cedric and Gloria. Stock HP is around 280. Looks kinda like this: You CAN use the pistons, cams, heads, modify the intake manifold a little and it will fit, the crank will fit as well, but the biggest advantage is the pistons, with their lower compression ratio. The crank, rods, and heads are pretty much the same. Nissan microfinishes the cams and crankshaft, and strengthens the rods and all their engines already. The intake manifold has no runners, just one big tube opening to all the cylinders.
As a side note, some guys in Japan recently built a VQ30DETT, and had it making MORE power than the RB26DETT...
5spd VLSD
15.2@92mph
180hp & 193tq
Faster than jOO!
Old 08-01-2002, 12:55 AM
Holyterror's Avatar
Holyterror Holyterror is offline
This VQ30DETT made more power than a stock RB26DETT... right? I don't see the VQ30 making 1000 hp with any original parts.
"There are no substitutions for revolutions."
Member of AF's Slide Squad (Member #05)
Bosozoku skyline gc110 mirage901 Completed Projects / Gallery 7 09-01-2010 11:13 PM
Tamiya R33 skyline Wolf95 Completed Projects / Gallery 25 08-28-2010 05:46 PM
will a R33 skyline rear diff match up to my 72 240z??? ocbro714 240Z | 260Z| 280Z | 300ZX (Past Z Cars) 0 12-05-2009 06:56 AM
Pictures of Skyline GTR R34 jason_bet General Discussion 0 07-19-2009 02:23 PM
AutomotiveForums.com R34 Nissan Skyline GT-R N1 RACECAR for sale on eBay igor@af General Discussion 0 04-10-2009 03:43 AM
