Old 05-30-2006, 05:33 PM
Silvers02 Silvers02 is offline
Exclamation AC compressors not coming on
My A/C compressors is not coming on when A/C is activated or in De-frost mode. I've check all fuses and relay's. Someone suggested that it maybe the magnet inside the compressor that is shot?!?!?!
Old 05-31-2006, 11:43 AM
wrparks wrparks is offline
Re: AC compressors not coming on
Have you checked to see if there is R-12 or 134A at high enough pressure. If the coolant is low or gone, the compressor should not come on or it would burn it up. I doubt the magnet is dead because it should be an electromagnet. If there is current it should pop in gear. The clutch could also be worn out.
Old 05-31-2006, 12:07 PM
2000CAYukon 2000CAYukon is offline
Disconnect the pressure cycling switch on the accumulator. Jumper a wire across the electrical connector. If the compressor comes on, then it could be:
1) not enough r12/r134a
2) the pressure cycling switch is bad
Before adding r12/r134a check the pressure on the low side. If it is below 25 psi for r12 or 21 for r134a, then you are low on freon.
If the pressure is higher, the switch is probably bad.
//2000CAYukon
Old 05-31-2006, 05:46 PM
kenwood guy's Avatar
kenwood guy kenwood guy is offline
Send a message via Yahoo to kenwood guy
//2000CAYukon
dont forget to purge your lines
Simon R
2001 Silverado W/T 4.3
124,000
Old 05-31-2006, 06:20 PM
wafrederick wafrederick is offline
Banned
There is a leak somewhere and the only way to find the leak is putting leak dye in.It will be easier to find the leak with a special light.The price of R134A has gone up because some of the manufaturers of R134A are supplying to the automakers only.
Old 05-31-2006, 08:38 PM
I might be wrong but you can also try using nitrogen just be sure not pressuerize over the max pressure of the evaporator then use a bubble solution to find a leak before that look at your guage pressure and see if its holding if it is then you dont have a leak
Simon R
124,000
