Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 05-30-2006, 06:05 PM
Black99GST's Avatar
Black99GST Black99GST is offline
Send a message via AIM to Black99GST
Turbos?
Anyone know anything about either of these turbos on slowboy's sale?
http://www.slowboyracing.com/more.php?id=5676&
http://www.slowboyracing.com/more.php?id=5675&
Anyone know what these turbos would be good for power wise with support mods? if it'll reach 400 WHP then...
Old 05-30-2006, 07:54 PM
MexRocket's Avatar
MexRocket MexRocket is offline
Re: Turbos?
. no.
STATUS: Near completion for the Engine
PROJECT BEST 1G IN IL:70% Done
MODS: C2 boost,mbc,B16GEGTurbo,12x28x3x3 FMIC,Ported2gmani,k&n.
Being bought in two weeks: Dsmlink,880's,3"exhaust,piping,suspension,axel,dri lled and slotted brakes.
Old 05-30-2006, 08:14 PM
Talon69's Avatar
Talon69 Talon69 is offline
Send a message via AIM to Talon69 Send a message via MSN to Talon69 Send a message via Yahoo to Talon69
Re: Turbos?
Nope IMO the evo 3 big 16g ported is better than them. But thats just my . They may disagree on here with me but the evo 3 will put out 400HP!!!
Current Cars
2006 Eclipse GT 6 speed MT (V6 3.8), mods so far- S Tech Springs, after market 18's, 2012 headlight Conversion, Greddy cat back exhaust, CAI, RRE Headers, Polyurethane Motor Mounts, NX Nitrous kit at 100 shot for now, RPM Window Switch, Triple Pod.
2003 Grand AM GT - official beater car for the winter lol
95 TSI AWD [email protected] (T-25)
Now fully Modded engine with 3,560 miles on it.SOLD
Old 05-31-2006, 03:58 AM
Thor06's Avatar
Thor06 Thor06 is offline
Jizzed In My Pants
Re: Turbos?
Did you even read the description? It said how much power they made at different boost levels and at 15 psi the bigger one made 330. I think it would top out closer to 380 or so on higher boost and more aggressive tune, but I dont really have any reason to believe that. Personally, I would go MHI evo 3 16g. Remember, 400 hp on the evo 3 isnt common. To my knowledge, its only been done twice with all the bolt ons (including SMIM and cams), with a pretty severe tune and a shit ton of boost.
Build on hold until I get a good paying job, either in school or once I get out. At that time a full tear down and complete rebuild should be in order.
The Purple People Eater will ride again... January 2011 can't come soon enough.
Old 05-31-2006, 12:14 PM
blk_srt's Avatar
blk_srt blk_srt is offline
Send a message via AIM to blk_srt Send a message via MSN to blk_srt
Re: Turbos?
go with an evo III and if you want bigger get a 50 trim
2004 Flame Red SRT-4
|Audiobahn 1200Q|Rockford 602s|Jensen flip out dvd|
Mods:
Old 05-31-2006, 03:18 PM
MexRocket's Avatar
Re: Turbos?
that is why I said NO already =P
Old 06-03-2006, 03:04 PM
Black99GST's Avatar
Re: Turbos?
what about a 20G? or the PTE SCM60? something along those lines? or yes, a 50 trim... i just want to make sure i buy the right turbo for my goals.
Old 06-03-2006, 03:07 PM
blk_srt's Avatar
Re: Turbos?
a 20g is an overpriced 50 trim.
Mods:
Old 06-03-2006, 10:15 PM
TheRomer TheRomer is offline
Re: Turbos?
http://www.slowboyracing.com/more.php?id=2200&
Want to buy that off of me? Good for close to 600 whp... .
Chris Winchell
95 GSX 12.5 ET with a 1.9 60' at 115 mph
Actually have traction this year
90 TSI <Project Acer>
2.0L, 2400 lbs AWD, t-67 goodness
Old 06-04-2006, 03:19 AM
ez1286's Avatar
ez1286 ez1286 is offline
Send a message via AIM to ez1286
Re: Turbos?
I'll make it three before i get a larger turbo, i have all those mods plus more and with the extra displacement and higher compression (9:1), I think i'll be around 400 whp maybe not i'm not sure.
95 GSX:FMIC, 6-bolt, evo 3 16g, 2600 act clutch, 1g bov (crushed), and a 3" turbo back exhaust, dsmlink, dks 272 cams, wideband 02, Coming soon 2.3L Stroker, 1mm oversized valves, crower sprigs. 91 TSI AWD auto, gm 3.5 maf, maft, fmic, emanage, profec e-01, 3" turbo bk exhaust +more little stuff.
http://www.ratemydsm.com/member/ez1286/?member=ez1286
Old 06-04-2006, 08:02 AM
kjewer1 kjewer1 is offline
AF - Advisor
Re: Turbos?
I went significanly faster on the 20g than I did on the 50 trim. Now, there is no real logical reason for this, but it just occured to me when I read this. I know my setup was still pretty weak on the 50 trim. In my humble opinion, the extra cost is worth it for poeple that prefer a non-hybrid turbo that bolts on. Whenever parts have to be modified, usually the turbine housing, there is always room for variability. I try to stick to full mitsu of full garret turbos whenever I can, since all of the parts used together were meant to be together, all with a predictable level of quality.
For the hybrid 50 trims, they range from 700 for SBRs housing, 800 for bulseye, nearly 900 for PTEs, and over 800 even for a full t3 garret. How SBR does it so cheap is a mystery to me, but naturally they want to push thier turbo I'd guess. The standard mitsu 20g is 900. So it's certainly not outrageously priced. I would spend the extra 100 for the 6H option, which pushes the cost out of the range of the 50 trims. But as I said above, that would be worth it to me to run the correct housing with the turbine wheel (they are designed for each other by each respective manufacturer).
So now we're talking 300 at most between the 6H20g and the SBR 50 trim, which is at least worth talking about. But for all the poeple that buy one of the other two closing the gap to ~100 bucks, I don't see the reasoning. With all the money poeple spend on these cars, what's 100-200 bucks in what is probably the most important and most fragile piece in the setup?
Of course, this is not to say that the 20g will last longer than the 50 trims, or that the 50 trims are handicapped because they use turbine housings their turbine wheels were never designed to work with. It's just something to think about, and something for me to ramble on about in my early morning boredom.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
