Weird noise
Today I noticed as I was driving my 99 Alero with the air conditioner on, I was hearing this weird noise from the fan or the air vents. I turned the A/c up higher, the noise got louder. And as I turned the AC down, the noise got quiter. Has anyone else had this problem before? Is it common?
Re: Weird noise
The bearing on the fan needs to be lubricated. You will need to remove the fan assembly and put some light oil or lithium grease on the bearing. This should quiet it down. If not you may have to replace the fan motor itself.
Re: Weird noise
Re: Weird noise
I recommend you to clean/replace alternator belt. I think this is source of noise you have. The tension force depends from air conditioner mode ... If belt went out -- sliding will occur .
