Old 05-30-2006, 12:30 AM
Drewet88 Drewet88 is offline
Tranny Bolt
Hello my friend Andrew gladly let me use his automotive forums account so I could post my question. I didnt want to make one of my own because I doubt I would be using it to ofter (I'm not really a computer person) but here is my question.
What should I do?
I was removing my tranny bell housing bolts and stripped the last one. U know the one that you have to go through the tranny to motor mount with a 24" extension to get to. For some reason that bolt was a tad smaller than the other tranny bolts and it got rounded off....
I tried hammering a smaller socket onto it and trying to turn it but that just stripped it more and now I have a perfectly round bolt.
Andrew tried helping me out but the only thing he could tell me to do was "drill it out." And when I said no he said "ask automotive forums." As a result I am here asking for your help.
Please help me get this last bolt off so I can finally overhaul my engine (failed a compression test pretty badly)
Thank you for reading this
DeAndes
P.S. this took me almost an half hour to write (I am not a computer person)
(\__/)
(='.'=) This is the original Bunny. Copy and paste bunny
(")_(") into your signature to help him gain world domination
*1987 Oldsmobile Ninety-Eight Regency Brougham.*
(deceased)
*2003 Ford Mustang GT*
just a CAI and Exhaust...for now
Old 05-30-2006, 12:41 AM
Alibi's Avatar
Alibi Alibi is offline
Send a message via Yahoo to Alibi
Re: Tranny Bolt
Yeah, Your'e probably going to have to drill it out. My first thought was to cut a groove in the bolt with a hacksaw and then use a large screwdriver to hopefully get it loose, but I'm not sure if it is even remotely possible to get a blade at the bolt to groove it. If you can get a welder to it, you may be able to weld another bolt to the rounded bolt and then try to unscrew it....but again you are left with the issue of space. Worse comes to worse, you will probably have to remove the entire tranny/engine assembly in order to access the bolt....
Good luck with it though
-Eric
89 LeSabre T-Type: CAI, STB, F41 Suspension, Moog Ball joints and tie rods, dual-out flowmaster and dual tips, Pointiac CD HU, Delco type 2 Ignition, etc.
Basic H/C body info:http://www.3800power.bravehost.com/index.htm
http://www.cardomain.com/ride/2318168
Old 05-30-2006, 01:51 AM
Re: Tranny Bolt
He doesn't want to drill it out because hs said it may make his bell housing weaker in structure. But I'm pretty sure he doesnt want to take out the entire tranny/engine assembly.
I think I'm going to try something I did a long time ago. I got a piece of pipe that was about the same diameter of the bolt head actually it was just big enough to slide over it. Then I got so JB Weld put it in the inside and let it sit overnight then I drilled a hole through the pipe and used a screw driver to turn the pipe which turned the bolt and I got it loose. The only problem is I didnt try it on a tranny bolt it was on a motor mount bolt and it was on an old ass Ford pick-up that was rusted so bad I had to scrap the project.
I dont know how well this will work on his car or if I can even find a piece a pipe that will fit over the bolt.
Maybe his best bet is to drill it out but I've never actually done that since he says its a 3/4 bolt (I thought it would be standard and not metric but I never saw the bolt before it got stripped) would I drill it out with a 3/4 drill bit?
He also told me to thank you for helping him out....
-Andrew
(\__/)
(deceased)
Old 05-30-2006, 08:32 AM
ChemMan ChemMan is offline
Re: Tranny Bolt
Sears sells special sockets for removing bolts that are AFU. They worked pretty well the couple times I've used them. Might be worth looking into.
Old 05-30-2006, 04:21 PM
Gocart879 Gocart879 is offline
Re: Tranny Bolt
this may sound stupid, but i have use channel locks, "craftsman" and a small vise grips before to remove these rounded off bolts. give it a try its always worked well for me,
Old 05-30-2006, 07:29 PM
spinne1 spinne1 is offline
Re: Tranny Bolt
This bolt is not accessible with vise grips. My advice is to go to Sears and get the sockets that remove stripped bolts. You'll need a fairly large one.
Old 05-31-2006, 12:27 AM
Re: Tranny Bolt
is the tool you're talking about called "pullers" because that was what my grandpa told him to go buy but when he asked autozone about them they said they didnt know what he was talking about and the only thing that he could do to get the bolt off would be to drill the bolt out...
(\__/)
(deceased)
Old 05-31-2006, 12:59 AM
Alibi's Avatar
Re: Tranny Bolt
Oooh...I didn't think about the rounded nut sockets at Sears...One of those ought to do the trick
Another thing I thought of the other day was to try a dremel tool with a cutting head on it to cut a slit in the bolt for a scredriver....or to cut off enough of the bolt to pound a socket onto the now size-modified bolt....
But I would try the sockets designed for stripped bolts...If I remember right, they aren't too horribly expensive and odds are you'll need em again down the road to merit buying them anyway. I know sears has them, or if you have a good mechanic buddy he may a set as well (rounded bolts are a common problem to us do-it-yourselfers-to-screw-the-(generally) overpriced-mechanic-ers)
-Eric
Old 05-31-2006, 03:51 AM
Re: Tranny Bolt
Hmmmm....
these sound like a tool I should add to my collection. Maybe I'll buy them for future use and just let him use them..
Do they come in different sizes like normal sockets?
(\__/)
(deceased)
Old 05-31-2006, 08:06 AM
Re: Tranny Bolt
Originally Posted by Drewet88
Hmmmm....
Yes, but there are not nearly as many as in a normal socket set.
Old 05-31-2006, 05:17 PM
LeSabre97mint's Avatar
LeSabre97mint LeSabre97mint is offline
Re: Tranny Bolt
Hello
Here is a link to the sockets that have been mentioned. http://www.sears.com/sr/javasr/produ...seBVCookie=Yes
Were you using a 12 or 6 point socket? I nearly always use a 6 point so the head doesn't get rounded out.
Dan
Wiswind's Windstar repair pics http://community.webshots.com/album/201931518cScpNK
Photos of my repairs: http://dansautopictures.shutterfly.com/
Check this out:http://threewheelmotorcyclemetro.shutterfly.co
A must read about problems Windstars have: http://www.automotiveforums.com/vbul...d.php?t=672854
95 Windstar 240,000+
98 Windstar 136,000+ 09-25-2008.
85 Dodge 1 Ton Snow mover gas hog
91 Mazda Protege free beater
SW MN
Old 05-31-2006, 05:27 PM
Re: Tranny Bolt
Originally Posted by LeSabre97mint
Hello
Dan
Thanks for the link but I do not know if he used 12 or point socket. I can ask him and repost later.
Hmmmm $60 not to bad and it looks like its something good to have added to my tool collection. But I'll have to wait until friday to get it
Maybe he can find someone to borrow one from until I but mine....
I'll ask around.
(\__/)
(deceased)
Old 05-31-2006, 05:31 PM
Re: Tranny Bolt
Second question where would be a good place for him to buy new bolts because he was talking about going to OSH or LOWE'S and I dont know how good their bolts are...
(\__/)
(deceased)
Old 05-31-2006, 06:13 PM
Alibi's Avatar
Re: Tranny Bolt
A transmission shop would probably have one laying around or an auto store...my local Napa has a large selection of bolts and I can usually find one. If not, then a junkyard would probably have one and I'm sure it would be cheap.
So far, it looks like the bolt-out set would be best. I was in Sears today and I saw a set for $20, but the largest nut in the set may not have been large enough for the bell housing bolt. However, there could be a set with larger nuts for a similar price, but if not then there is that nice-looking 60 dollar set.
-Eric
Old 05-31-2006, 08:07 PM
Re: Tranny Bolt
I just came from sears and bought the $60 set. It looks like it should have every size bolt in it. I'm going to look at it now.
But it doesnt look like the sockets will fit onto my breaker bar because the back is round?
Maybe I have to go buy an adapter.
Man he is going to owe me I'm buying tools that I wont need to use anytime soon so he can finish his project.
(\__/)
(deceased)
