Old 05-29-2006, 08:30 PM
TeamRedLine23's Avatar
TeamRedLine23 TeamRedLine23 is offline
Send a message via AIM to TeamRedLine23
running wideband o2 sensor wires?
I just installed a aem wideband o2. I drilled and welded the o2 sensor to the exhaust. What is the best was to run the wires, from under the car to the caban? thanks
1997 Eclipse GS-T
Performance modification:-evo3 16g-K&N Intake-HKS SSQV b.o.v vented-2.5'' Dejon tool blow thru upper and lower-Dejon large smic-GM MAF-MAF Translator-HKS 3" Carbon Fiber Titanium TBE-stock fuel rail-Walbro 190 fuel pump-PE 650cc injectors-Accel Thundersport wires-NGK series 7 spark plugs-1g intake mani/head-
Interior Modification:-Autometer Boost Gauge
http://www.cardomain.com/id/xTeamRedLine23x
Old 05-29-2006, 09:04 PM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
Re: running wideband o2 sensor wires?
Zip tie it to the main harness in the engine bay and then drill a hole in the firewall by the clutch pedal and install a grommet and then run it through that.
95 Talon TSI AWD
97 Eclipse GST
Old 05-29-2006, 09:36 PM
kjewer1 kjewer1 is offline
AF - Advisor
I always bring the O2 sensor wire in where the stock rear o2 sensor came in. Under the drivers seat on the 2g, and the passenger seat on the EVO. Works well since I tend to use the stock rear sensor location anyway. The 1g doesn't have these holes premade, but you could do something along the same lines. Most poeple put the WBO2 box up under the dash/ECU/glovebox area, so coming in through the floor lends itself well to those locations too.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
