Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 05-29-2006, 06:21 PM
LXA LXA is offline
Hitch Install - weekend project gone awry
I ordered and thought I would quickly install a Reese hitch (supposedly just for this truck) this weekend. Well, wonder of wonders, I ran into a problem. It seems the distance between my frame rails is 38 1/2", while the outside measurements of the hitch is 38 9/16-5/8. So that raised several questions:
1) Do I indeed have the right hitch? Everything else looks like it matches and lines up perfectly.
2) Is that the correct distance between the frame rails or is something bent?somehow. I get no indication (shaking, swerve, etc.) when I drive it that the frame is bent.
3) Grinding down the hitch doesn't seem to be the best idea, for strength/integrety of the metal. So, I was thinking that the frame has to have a little "give" or flex to it and was wondering if I put one of the rear wheels up on an incline, would that "flex" it enough to get the hitch between the rails?
4) Has anyone else had this problem or any other ideas for a fix?
Thanks for any suggestions!
Oh, and I found a quick and fairly easy way to clean out those nasty rusted bolt/nut welds. WD40 (obviously) and the short metal brush from a battery cable cleaner makes fast work knocking off the rust and dressing up the threads. Took about half an hour and I could hand tighten the bolts without much problem.
1993 Rodeo LS Auto 4X4 3.2L V6 141K Mi
1993 Rodeo LS 5sp 4X4 3.2L V6 234K Mi - now living eternally and serving proudly as a parts car to the above
2001 Caravan Sport (wife's)
1979 MG Midget (project w/ no progress - anyone interested?)
1910 International Touring Car (most reliable of the bunch!)
Old 05-29-2006, 08:01 PM
rodeo02 rodeo02 is offline
Re: Hitch Install - weekend project gone awry
Could you 'adjust' the hitch slightly with a vise/big hammer? I've had to do that before with *direct fit* hitches. The hidden hitch (brand) hitch I put on a 2003 rodeo was a snap aside from the washers you had to fish to the correct position thru the hollow frame rail.
G/luck
Joel
2016 Subaru Forester 2.5i base CVT
2016 Nissan Quest SV
Old 05-29-2006, 09:18 PM
Gizmo42's Avatar
Gizmo42 Gizmo42 is offline
My Curt Mfg hitch was slightly narrower then the frame rails. Had to use supplied washer between it and the recovery point mount on the left side. Even fishing the nut and washer through the frame rail went pretty easy.
The hard part for me was cutting off the modified reciever the previous owner had welded to the frame If I didnt need to put my spare tire under there I would have left it.
--Dave
1999 Rodeo LS 3.2 4x4 5 Speed
32x11.50-15 BFG T/A KO
3" Lift - Rancho 9000x
Rear No-Slip Locker
Flowmaster 2.25" 50 Series
There is a very fine line between "hobby" and "mental illness." - Dave Barry
Old 05-30-2006, 11:34 AM
LXA LXA is offline
Thanks for the suggestions. I was trying to avoid using the brute force method on the hitch. With my luck a weld would break. Though it may come to that.
Any thoughts on flexing the truck? Is there enough give in the frame or is that just a stupid idea?
Old 05-30-2006, 05:36 PM
Gizmo42's Avatar
The frame is pretty stiff so I dont know that flexing it would work. You could try taking just a small amount of metal off the frame and the ends of the hitch. You are only talking 1/8 - 1/16" overall so you wouldnt need to take very much off any one peice. You might be able to pound it into place then.
--Dave
Rear No-Slip Locker
Old 05-30-2006, 09:18 PM
96IsuzuRodeo 96IsuzuRodeo is offline
I installed a DrawTite hitch on my Rodeo and it was a tight fit just like yours.
I used a block of wood and a 4 pound hammer to drive it into place. An extra set of hands will help a lot when you are doing this.
There should be enough give for it to slide between the frame rails. You may want to try rubbing some bar soap on the frame rails and the hitch where it makes contact before you drive it into place. It should pop into place just fine.
