Old 05-29-2006, 05:15 PM
buster007 buster007 is offline
EGR Valve 2000 Taurus 3.0
Can someone tell me how to remove the EGR Valve ?
Old 05-29-2006, 10:16 PM
shorod's Avatar
shorod shorod is offline
SHO No Mo
Re: EGR Valve 2000 Taurus 3.0
Yep, care to elaborate on what you are trying to accomplish? No offense, but there are some common issues on the Taurus related to the EGR and the DPFE sensor. I'd hate to have you remove the EGR trying to solve a problem that is commonly caused by something else.
If you'd like to private message me with an e-mail address for you that can accept PDF attachments, I can e-mail you a PDF file of the service manual steps for removing the EGR.
-Rod
Old 05-30-2006, 08:01 PM
I am removing the valve because the "check engine" code stated the valve was faulty.
Old 05-30-2006, 08:45 PM
shorod's Avatar
SHO No Mo
The offer still stands to e-mail you the PDF procedure for EGR replacement.
I would suggest that before you replace the EGR valve, you post the exact code you are seeing on this thread.
-Rod
Old 05-31-2006, 06:39 AM
way2old's Avatar
way2old way2old is offline
TOKEN HILLBILLY
I agree with Rod. You need to diagnose the concern before you replace parts. Would you please post the code you have gotten from the vehicle? If it is a P0401, or a P0402, the EGR valve is probably not at fault. Also there is a vent valve in the system and carbon build up in the EGR ports will also cause problems and a trouble code. There is NO CODE that will tell you to replace a part. The parts are replaced after careful diagnosis.
Being way2old is why I need help from younger minds
The sooner you fall behind the more time you'll have to catch up.
HEY Y'ALL--READ THIS
Here are some of our old vehicles for sale.
Old 05-31-2006, 11:08 AM
Thanks for the advice .. once the "check engine" light comes back on, I will have the code read and post here.
Old 05-31-2006, 11:46 AM
way2old's Avatar
TOKEN HILLBILLY
A scanner should be able to read history codes and let you know if there is a code even if the light is not on.
