Go Back   Automotive Forums Car Chat > Volkswagen > Jetta/Vento/Bora > '97 - '03
Old 05-29-2006, 05:09 PM
deadpossum deadpossum is offline
Sparkplugs
I need help in replaceing the sparkplugs on my '01 1.8T This sounds crazy but I've never worked on this motor before.. Pics would be nice!
Old 05-30-2006, 10:15 PM
FemaleVwTech's Avatar
FemaleVwTech FemaleVwTech is offline
Post Re: Sparkplugs
Ok, thats not to hard.
You will need to removed your top engine cover. Then you will beable to see three coil packs and a little box like thing with a vaccum line to it. Remove the 10mm bolt that holds it to the bracket. Then there is three 5mm herx bolts that hold the brakect to the valve cover. Remove the bolts. Now, you will bealbe to see all four coil packs. Take a screw and place under the coil and push up on the coil to remove them.
