Go Back   Automotive Forums Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 05-29-2006, 02:38 PM
The1NamedMarc's Avatar
The1NamedMarc The1NamedMarc is offline
Send a message via AIM to The1NamedMarc
Disconnected Alarm... now car wont turn over.. Starter?
I had disconnected the alarm from my 90 camry and now the car wont turn over. When the key is switched into the "on" position, there are several clicks from inside the engine bay. One sounds like it comes from the fuse box and immediately following that is two quick clicks from the starter.
Did I somehow ruin the starter when reconfiguring the wires from the alarm?
All help is appreciated.
Old 05-29-2006, 03:45 PM
popeye08 popeye08 is offline
Re: Disconnected Alarm... now car wont turn over.. Starter?
What you have done is just like what a thief supposed to do. I don't think it will ruin your wire, but you'd better find a dealer to get rid of it. Did you try to connect the alarm and try it again?
AccordCodger AccordCodger is offline
No, you wouldn't have wrecked the starter. What you MIGHT have done is not overriden the immobilizer function of the alarm.
I have no idea how to fix that. Why did you disconnect the alarm?
Old 05-29-2006, 05:42 PM
I totally got rid of the alarm and returned it to stock form. (There is no longer a "brain" or wires connected to the vehicle) The alarm was no longer functioning properly and would just go off randomly.
Old 05-29-2006, 07:16 PM
InstallTech's Avatar
InstallTech InstallTech is offline
I'd make sure you have your starter wires from the ignition switch wired together properly...(ie. solid connection). If you don't have a solid connection, then a solid signal can't reach the starter. That is assuming, of course, that you had a "starter kill" wired in with the alarm. If that doesn't work, did you try to jump start it? Seriously. No insult intended at all, but it sounds symptomatic of a low battery or bad connections at the battery. Just covering all the bases.
I reject your reality, and substitute it with my own.
Old 05-29-2006, 08:48 PM
Here is what the drivers side kick panel now looks like...
This picture was taken behind the steering column...
Old 05-29-2006, 08:52 PM
InstallTech; I'll try your suggestions tomorrow, but everything with the battery should be fine. (All the accessories work perfectly)
When I was reconnecting the wires, I made the mistake of putting a piece (circled below as "added this") to the starter/accessory wires. (It was a looping black/white plug) Once I started the car, it defintely sounded like something blew.
I didn't realize that the black/white and black/yellow wires were supposed to be left alone on a stock car....
Old 05-29-2006, 08:55 PM
If it sounded like something blew, disconnect that connector, check all of your fuses, and try to start the car again. Electrical problems are *really* hard to diagnose without having the car around to put a meter on.
Old 05-30-2006, 09:45 AM
I'll check all the fuses now but why do I still hear all the clicking sounds? Wouldn't those be non-existant if there was an electrical problem?
EDIT: I just finished checking all the fuses on the drivers kick panel and engine. Also, I made sure all the wires were connected properly.... still nothing.
There's no way an electrical problem could ruin the starter?
Old 05-30-2006, 02:03 PM
RIP's Avatar
RIP RIP is offline
AF -Advisor
Are you getting a constant 12 VDC at the small connector on the starter when you hold the key to start? If so, you know what to do. If not, go backwards in the start system (starter relay, neutral/start switch, ignition switch, battery) till you find 12 VDC and go from there. If you already did, pardon me for stating the obvious.
Old 05-30-2006, 09:39 PM
Problem solved... thanks for everyone's help!
Old 05-30-2006, 09:48 PM
Great to hear. What was the deal?
Old 05-31-2006, 03:01 PM
I'm not even sure; What I did was put everything back except for the cut wires and the ignition plug. Started right up and hasn't caused any problems. It's a shame I didn't think of that first cause it would've been quite easy to just switch the ignition plugs...
