Go Back   Automotive Forums Car Chat > Chrysler > Lebaron
Old 05-29-2006, 09:35 AM
funnsun funnsun is offline
89 lebaron rough idle
I have 89 lebaron GTC, I have a rough idle when I first start and I can smell fuel. Idle gets better when car warms up but idle is fast. I get a code 34, which is open or stuck cruise controll???
Old 05-29-2006, 07:56 PM
94LebConv3La604 94LebConv3La604 is offline
Re: 89 lebaron rough idle
actually it is this:
Fault Code 34
Synopsis
Notes: For vehicles equipped with speed control
Description: Speed control solenoid(s) circuit is open or shorted
Power loss light: Off
Limp-in mode: None
Possible Causes
Bad connection or wiring - Check the wiring and connections between the logic module and the solenoid. Clean and regrease any corroded connectors with dielectric grease and repair any shorts.
Bad solenoid(s) - The speed control is located near the battery and will have to be disassembled. See the Understanding Solenoids page for information about how to test and repair solenoids.
Diagnostic Method
Trigger Parameters
- Near 0V or near 12V not detected when either solenoid is turned on or off, respectively
Results If Component Fails
Fault code 34 is stored.
This info is from http://minimopar.knizefamily.net/fault/
