| Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible. |
Sputtering GS
My girlfriend has a 97 gs and its been running rough like sputtering when you let it idle.. the check engine light is also flashing most of the time and it feels like it is maybe missing a cylinder..
any ideas of what to check first?
![]() ![]() SOLD '97 GSX EvoIII 16g, FMIC shortroute piping, FIC 850's, DSMLink V2.5, 3" turboback, mbc, Walbro 190 rewired, autometer boost gauge, Tokico shocks/springs -2", Motegi MR7 18" hyper black wheels '05 blacked out f150 FX4 |
Re: Sputtering GS
Spark plugs
'92 3000gt SL Zoom Stage 1 Clutch Quote:
Re: Sputtering GS
Re: Sputtering GS
do gs's and gsx's have the same spark plugs?
Re: Sputtering GS
Yes.
Re: Sputtering GS
Re: Sputtering GS
It ended up being water in one of the spark plug holes so i took care of that and let it dry good and it runs perfect now..
does anyone know the order the plug wires go on a 97 gsx? To which cylinder
Re: Sputtering GS
4123 from the coil 4321 on the motor both passenger to drivers side
2004 Flame Red SRT-4 |Audiobahn 1200Q|Rockford 602s|Jensen flip out dvd| Mods: ![]() |
Re: Sputtering GS
how did water get in there? does she have a "cold air intake"? (water sucker)
Re: Sputtering GS
BTW, my CAI hasn't sucked up any water in over a year of ownership.
Re: Sputtering GS
i just washed mine last night and it has the same problem. i used that "GUNK" degreaser, then hosed the whole engine bay. There were still suds in that little 12x6 space where the plugs go into the motor, and i really washed it down, it was overflowing with water. today on the way to work it was running really lean, really crappy, really slow. ill check the plugs and wires and see if maybe they are wet, plus this gives me an excuse to put new 7es plugs in :-)
ps-if there was a little bit of water in the spark plug sleeve/hole/whatever, and then it dripped into the cylinder, that wouldnt be enough to hydro-lock the motor or anything right? also, if the car was off when i sprayed it down, could i have accidently sprayed too much water on the air filter, enough to mess it up like it is? thanks |
Re: Sputtering GS
ok i just replaced the spark plugs, there was water in the far driver side spark plug hole (just a few drops). started the car up, and it still runs the same way. what else could be wrong?
Re: Sputtering GS
Try replacing the plug wires if new plugs didn't change anything. Those two are usually the most common after washing the engine bay. Just a piece of information for next time though, try not to soak the coil/plugs/wires with water and then letting them sit. If you get them wet, blow them dry with some air, same for the plug holes.
Re: Sputtering GS
what would a new coil and/or CAS cost? where could i go to get these?
Re: Sputtering GS
