Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 05-28-2006, 10:32 PM
Hpnotiq86's Avatar
Hpnotiq86 Hpnotiq86 is offline
Send a message via Yahoo to Hpnotiq86
Serious RS-T Question....
Ok, so I have a $7,000 loan to spend, plus a little extra cash i have saved, and what i'm SERIOUSLY wondering is if I should perform the following mods to my current 1997 RS:
Bottom-End Engine Components
1. Wiseco Forged Pistons - 8.8:1 Compression (turbo) - Standard bore (piston rings included) - $481.52
2. Eagle ESP H-Beam Connecting Rods - $330
3. Clevite 77 H-Series Rod Bearing Set - $49.95
4. Clevite 77 P-Series Main Bearing Set - $49.95
5. ARP Main Stud Kit - $199.95
6. Fel Pro Lower Gasket Set - $39.95
Top-End Engine Components
1. Crower Cams (pair) - Stage 2 - Agressive street use or nitrous/turbo. Idle 1000 to 7000 RPM - $434
2. SBR Stage III 420A Head - 100% Hot Tanked - Fully Pressure Checked - SBR 5 Angle Valve Job - SBR Stage 3 Port Work - New Valve Stem Seals - New Stainless Steel, Undercut Valves - New Valve Guides - Crower Springs and Retainers - Fully Decked Head surface - $1,499
Turbo Kit
1. SBR - Intercooled Kit w/ Fuel Upgrade - $3,695 (see www.slowboyracing.com for details) and this kit cost pretty much exactly what it would to build a kit with the same components on your own, which is why i like it.
Drive Train
1. ACT 2600 Clutch Kit w/ Street Disc - $462
OR get a 97+ GSX and do what I can to it with the extra cash....I was really leaning toward building the sick 420a..but i figured i'd throw it out to the online community.
Thanks.
Old 05-28-2006, 10:51 PM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
Re: Serious RS-T Question....
I say build up the 420a, theres not that many of them out there. If you set up everything right they can put out some serious power. Your set up looks good so far, but I think you need to pay a little more attention to your fuel. Since the motor is built you will probably be running high boost, it seems you have a big budget so you might want to look into a megasquirt fuel system.
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
Old 05-28-2006, 10:52 PM
steviek's Avatar
steviek steviek is offline
Well I guess one main question is do you care about all wheel drive? And you gotta also take into account how much time it will take you to do that. If its a hobby for you then it doesn't matter but if its a labour because you really want a turbo then you gotta decide how much your time is worth. Your upgrades seem good if thats the route you choose to go no problems there I can tell you've done your research. So I guess its really up to you. I like the AWD but I don't want to persuade everyone to get one cause when its time for me to buy another one they'll be none left.
FP 18g turbo e3 o2 & mani, 3" exhaust, , 7 bolt, wiseco/eagle, walbro 255hp re-wired, Aeromotive FPR, FIC 1150cc, injen intake, greddy RS, aem wideband, turbo xs mbc, act 2600 clutch sprung 6 puck, BC 272's, dsmlink v2.5, ETS FMIC, Devils Own, JMF SMIM.
18 Inch chrome rims
In closet AEM Fuel Rail, SS Lines,
1997 TSI AWD
Diamonds Are 4Ever
12.7 @ 107
http://i83.photobucket.com/albums/j2...y/DSC00461.jpg
Old 05-28-2006, 10:58 PM
Hpnotiq86's Avatar
That turbo kit comes with an Apexi S-AFCII, Accell 550cc Injectors and a
Walbro 255 Fuel Pump...that not good enough? I plan on running about 12psi daily, and 20+psi on track night...
Oh, and I see a Quaiffe LSD approaching soon after these mods come into play...other wise AWD is just a heavy waste to me, besides most of my racing will be done from a roll anyways...
Any other opinions or suggestions?
Thanks.
Old 05-29-2006, 12:58 AM
l_eclipse_l's Avatar
l_eclipse_l l_eclipse_l is offline
Imagine what $7k puts you at with a 4g63. Even if you sell your car and it costs you an extra $1-2k to get the GSX, you still got $5k to dump into it and make it a monster. It just seems like a waste of money on the 420A. If you want the most power for your money, get the GSX. If you want originality and to do something not many people do and don't care about what it costs vs. what power you make, build up your 420A.
'92 3000gt SL
Zoom Stage 1 Clutch
Originally Posted by kjewer1
I disagree. Better is better. Bigger is just bigger.
I just made that up, and I like it.
ez1286's Avatar
ez1286 ez1286 is offline
Send a message via AIM to ez1286
Honestly i'd say got for a gsx. Awd > everything and everyone.
95 GSX:FMIC, 6-bolt, evo 3 16g, 2600 act clutch, 1g bov (crushed), and a 3" turbo back exhaust, dsmlink, dks 272 cams, wideband 02, Coming soon 2.3L Stroker, 1mm oversized valves, crower sprigs. 91 TSI AWD auto, gm 3.5 maf, maft, fmic, emanage, profec e-01, 3" turbo bk exhaust +more little stuff.
http://www.ratemydsm.com/member/ez1286/?member=ez1286
Old 05-29-2006, 02:05 AM
Killa's Avatar
Killa Killa is offline
agree
GM FOR LIFE !!
NEW 1997 Camaro z28 6 speed
illa never going back to import , but killa alway be nice to any DSM he saw
looking for 2002 Trans Am LSX
UPGRATE 2010 !! 97 Camaro Z28
95 camaro lt1
1992 Pontiac Firebird v6 auto -sold -
Pony 1998 Mustang GT 4.6L Manual. Black
1995 Eagle Talon TSI AWD Turbo manual R.I.P
1994 Mitsubishi Eclipse Manual gray -Sold
1997 Mitsubishi Eclipse RS Auto White - Sold
Old 05-29-2006, 02:20 AM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
Everything looks good on paper, but can you actually do these mods is the question. I used to want to build up my 420a, then I got a TSI AWD and have a monster motor for it, now I'm back to wondering what to do with my 420a. If I were you, go ahead and build it up, there aren't that many of them out there and you'll have something a little more "out of the norm." Or you could do a 4g63 swap like I'm seriously considering
95 Talon TSI AWD
97 Eclipse GST
Old 05-29-2006, 03:30 AM
Hpnotiq86's Avatar
Thompson, what do you mean, "can you actually do these mods"? Ofcourse I can...with the help of a few friends that is. And how can ANYONE call doing something to make an unlikely/unique engine 4x as powerful as it was stock, a WASTE? of money....wow.
Anyways, for some reason I can't stop thinking about this (obviously, im up at 4:35AM posting still...), but I can't see how you guys figure $7k straight into the 420a and drivetrain isnt going to out perform a GSX with $3-4k tops invested. I mean, isn't a $850 LSD good for any kind of traction in a FWD? and even if I wouldn't beat a AWD in 60-80' I think I could pull hard on him the rest of the 1/4...
I don't know, maybe i'm just being too stubborn to let my "dream" go, and besides, a 350+ whp 420a would be quite unique/friggin' sweet sleeper, and I should think it would satisfy my needs, especially in my location...regardless of if could beat a GSX with the same amount invested or not. There will always be faster cars no matter what I do...
So, FINAL QUESTIONS!!
1. Mid-Top end...what would take it (no AWD bias!): My 420a as listed above w/ $7k in it, or a AWD 4g63t w/ $3k in it.
2. How strong is my (420a) block, and will the stock crank hold-up to these mods?
Thanks.
Oh, and my car KBB's for something like $3k, and a nice '97+ GSX would run right around $7-9k, correct? And my total CASH budget is $7,500 to buy and mod a GSX....meh..
Old 05-29-2006, 03:43 AM
I just asked because there are people that ask about doing these mods and they don't know the first thing about an engine, they would be lucky to change their own oil, sorry if I offended you. And I never said it was a waste of money, in fact I might be building up my own 420a so I don't know where you read that I said it was a waste of money.
Anywho, a modded 4g63t will always outperform a modded 420a with the same amount invested, that's just the way it is. As for your 420a block, it can hold quite a bit of power if built right. Hahn is running 10's on a 420a block and still on the stock head!! If done right, it can be a very strong and very powerful motor.
95 Talon TSI AWD
97 Eclipse GST
Old 05-29-2006, 03:50 AM
Hpnotiq86's Avatar
Yah sorry, I was actually quoting |_eclipse_| about him calling it a waste of money, not you lol.
So, no worries about the block that's good...but what about the crank? Also, about that first "final question" in my last post about the mid-top end perfomance (top speed, and high speed accel.)....any ideas?
Old 05-29-2006, 03:59 AM
I'm not sure about the crank. I know I've seen some performance cranks for the 420a being sold somewhere, but I can't remember where, I'll do some searching in the morning.
About your final question, I don't know if I completely understand what you're asking. If you want to know which will be better at what stages, the AWD will own anything off the line but the 420a will probably be faster in the long run just because of the drivetrain loss (even though it is minimal).
Also, in your first post, I don't see how peiceing together your own turbo kit would cost anything NEAR as much as the kit you posted. I could probably find a damn good setup for roughly $1500-$2k. It all depends on where you look and what you're looking for, but $3700 for a turbo kit is fucking insane, I don't care if you're Dave Buschur, that's still too much. Alot of that kit is just a bunch of their stuff put together in addition with some others, all of which are brand new and you are paying top dollar for. Their "Intercooled Kit" just has their intercooler added on which is like $800, about $500 too much for a good intercooler. There are others too, that's just a prime example.
95 Talon TSI AWD
97 Eclipse GST
Old 05-29-2006, 04:22 AM
Hpnotiq86's Avatar
Honestly, I picked every single specific part that SBR had listed for that kit, and searched around a little on each of them and the price really did come out within a couple hundred dollars of my pieced together one, and theirs. Now the kit included a rather large FMIC, 550cc injectors, and S-AFCII. Or maybe I just looked in the wrong places for parts...I don't know. I know I have a thing for buying used parts though...some things are OK but other stuff....i'm weird about, I can get over that though.
...and yes that's what I was getting at about the whole mid-top end range, I have no doubts about AWD ripping me a new asshole off the line, and possibly keeping a few car lengths on me for maybe an 1/8 mile before I pulled on him if not passed him completely, all depending on who im racing.
So bottom line...I think i'll build me one hell of a 420a then once that loan is paid off...take out a $12k one and THEN hit up the whole AWD world.
I guess my view on cars is to mod it while youve got it, and move on...
Thanks for all your help thompson, and I would still really like for others to post what they think about it...
Also, one last thing.....if someone could help me piece together the strong kind of turbo kit i'm looking for for a reasonable price...i'm pretty much an idiot when it comes to knowing what new parts are worth, whats a steal, and whats a rip off ...so if ANYONE wants to help me on that one...feel free.
My E-Mail is [email protected]
Old 05-29-2006, 04:27 AM
I was planning on doing that tomorrow anyways to show you the price difference. It may be a big difference (which I'm betting on) or it may not be and it also depends on how much work you want to put into it yourself. I know that I could make a turbo manifold instead of spending $200 on one that would work just the same. There's an interesting link on www.2gnt.com about a DIY turbo kit but the damn site isn't working right now. It's under the tech articles if you get it to work. But enough of this, I need to get at least 4 hours of sleep before work.
95 Talon TSI AWD
97 Eclipse GST
Old 05-29-2006, 04:32 AM
Hpnotiq86's Avatar
Ok, I better sleep some too, but just get on AIM sometime tomorrow...i'll be online random times of the day. I'll just check if to see if you're on when I am. It would be alot easier to communicate in IM's than in a forum....
G'night then.
