Go Back   Automotive Forums Car Chat > Honda > Integra
Old 05-28-2006, 09:40 PM
wiz33064 wiz33064 is offline
Unhappy 94 integra NO SPARK PLEASE HELP !!!!
just put new plugs,dist cap,rotor button and wires.. Have no fire ....was running rough before i did this..now i have no fire at all...any help would be appreciated..1.8 L engine manual trans
Old 05-30-2006, 05:06 PM
nitebeest nitebeest is offline
Re: 94 integra NO SPARK PLEASE HELP !!!!
Double check to make sure that the spark plugs are torqued in all the way. I've heard stories of peoples spark plugs being a full turn out and the same thing happens. Also double check to make sure that the cap and rotor are in there properly and that the rotor is hitting where it is supposed to on the cap. Also double check to make sure that the spark plug wires are in all the way. Though I doubt that you have all 4 not in all the way it is worth a shot if the spark plugs, cap and rotor are all fine. And just curious, but are you getting a CEL or any trouble codes?? If you are, read it and that might help you with the source of your problem.
Old 05-30-2006, 10:43 PM
superbluecivicsi superbluecivicsi is offline
AF - Advisor
battery voltage reads? all power terminals are tight? otherwise, id say swap out coil and ignitor(icm) for known working one.
96-00 civic and 94-01 teg coils are exactly the same. obd1 civic icms are the same. 94-95 teg icms are the same. 96-01 teg ignitors are the same. different obd1 and obd2 civic and teg ignitors are interchangable and the same assuming you swap out the different icm mountings.
99 [email protected] psi si- I voted for the Terminator for Gov.
95 HB- B16a2- SC34@12psi
WTB: USDM B16a2 or B16a3 complete short block. pm is the key.
FS: B series InlinePro cast mani, PnH RC 550s, and Hondata S2b. pm me.
Old 06-01-2006, 08:08 PM
Thanks all will try that and get back with you
