Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 05-28-2006, 08:37 PM
that_guy5's Avatar
that_guy5 that_guy5 is offline
Help!!! Spark Plug!!
OK I WAS GOIN TO CHANGE MY SPARK PLUGS ON MY CIVIC AND WELL TO GET TO THE POINT I WOULD NOT COME OUT WHAT SO EVER I TRIED AND THAT DAM THING IS STUCK, IS THERE ANYTING THAT I COULD USE TO MAKE IT COME OUT SOMEHOW !!!:
Old 05-30-2006, 10:30 PM
superbluecivicsi superbluecivicsi is offline
AF - Advisor
Re: Help!!! Spark Plug!!
get some extra torque and go counter clockwise
99 [email protected] psi si- I voted for the Terminator for Gov.
95 HB- B16a2- SC34@12psi
WTB: USDM B16a2 or B16a3 complete short block. pm is the key.
FS: B series InlinePro cast mani, PnH RC 550s, and Hondata S2b. pm me.
Old 05-31-2006, 11:03 AM
big tex84's Avatar
big tex84 big tex84 is offline
Have you overheated the engine b4? if so then you may have fused the threads from the head and the threads of the spark plug together, not a good thing.
Finally getting my swap done, Thought I would be relieved and satisfied, now I just wanna spend money on other car parts, WHERE DOES THE MADNESS END!!!!
Old 06-01-2006, 08:43 AM
mennouth mennouth is offline
Or somone cross threaded the pluggs and JB welded them in. i would sugest trying some PB blaster aroung the base of the plugs, if that is of no avale take the head off and look to see if remnants of JB weld on the plug thread, a compression test should tell you if you got it hot enough to fuse the plugs to the head, the head will be warped or cracked, it takes lots of heat to fuse head to plug, if there are no signs of a blown gasket ie is it puffing white smoke, does it seam to loose its balls either in lower RPM or in higher RPM, or simply run rough, IE missing on one or more cylindar.
explanation short, soak them in PB blaster, try and loosen them if that doesnot work, take a socket that is just big enouth to go around the isolator, "the white part" and rest on the top of the metal, "where the scocket usualy grabs" and tap it GENTLY with a hammer, if it is coroded or torqued to tight, the slight vibrations will help loosen it, and let the penetrating oil into the threads, PB blaster will not harm your combustion chamber.
good luck, when you get them out use locktite anti siez on the threads, and only torque to specs,
Old 06-01-2006, 11:05 AM
big tex84's Avatar
that is not neccisarily true, the head does not have to be warped or cracked,
usually the head is intact without signs of distress
Old 06-02-2006, 11:20 PM
that_guy5's Avatar
Thumbs down Re: Help!!! Spark Plug!!
i remember my dad changed them b4 with out no prob but then when i tried to take that one out its a pain its only 1 though the 1 on the driver side # 4 i think but yea my kar overheated once but no big deal something stupid that i did. i put some lubricant i forgot what it was and let it sit for couple of hrs and still no budge i let my friend he is a big guy and even he couldnt make it loose but oh well am ready to say screw it but everything else seems to b ok so far but is there anything else i could do 2 solve this prob???
Old 06-03-2006, 09:54 AM
AF - Advisor
put this
on the end of the handle of this
and then use some muscle.
