Go Back   Automotive Forums Car Chat > GMC > Jimmy
Old 05-28-2006, 09:35 PM
Junky1991 Junky1991 is offline
Cool Ok, I got it ordered......now what.......
Ok, went on ebay today and got a nut kit....I wanted to do the nut kit and the injector assembly but im broke and would like to have my Jimmy on the road sometime this century. Now is there any pointers or anything to make the job easier....I removed the hood because it was annoying me so that is not an issue and everything is torn apart waiting for the....part . So any knowledge and tools that I will need will be great. Thanks in advance.
Old 06-01-2006, 01:30 AM
turbovanman turbovanman is offline
Re: Ok, I got it ordered......now what.......
What year? Whats a nut kit? do you mean spider assembly?
1998 Jimmy-full load
1989 Turbo Caravan-13.4@98 mph-12's were soo close,
Simon
Old 06-01-2006, 09:05 PM
Its a 1993 GMC Jimmy S-15. The nut kit is the supply and return fuel lines, it comes up to the manifold and then goes into the spider assembly. Just wondering if anyone has any pointers for me on installing the kit.
Old 06-02-2006, 01:18 AM
Pretty simple, remove the upper plenum, then you will see the horseshoe clips holding the lines on at the reg. Undo the fuel lines first, 16mm and 3/4 wrenches. Put a rag over the fittings so you don't get a face full. Use a flat blade screwdriver and remove the clips, remove the fuel lines carefully. Put some silicone spray or lube on the o-rings and put it back together. Make sure the metal fuel lines still have there o-rings still attached. Clean out the carbon out of the EGR passage, clean the throttle body with carb cleaner and a tooth brush. Reassembly and go have fun.
Simon
Old 06-02-2006, 08:37 AM
excheezhead excheezhead is offline
somewhere back a few months ago, one of the moderator/ASE guys posted a service bulletin from gm about the injectors, both csfi type and the new mod. mfi, it was a fix to customer complaints about this type of injector problems and explained in detail with pictures and part breakdown on how to clean the old style injectors(spider/cfsi) and if the cleaning didn't work, to consult the owner about the mod to new mfi injectors. it even included part numbers for o-rings, nut kits, gm brand cleaner, etc, with a part list for gmdirect for the conversion to mfi. i checked and the parts from gm to do the conversion are between $275-325USD depending on whether you order the lub, cleaning fluid, etc from them or not.
Old 06-06-2006, 09:52 PM
Is that the procedure for pre vortech 4.3ltr engines? I have the vortech engine so dont have the TBI, just that spider assembly.
Old 06-07-2006, 01:49 AM
That is for the 95 and earlier W engines. 96 and up got the new style. Vortech is GM's brand name and they even called TBI's Vortechs in the early 90's. TBI's are engine code Z, 96 and up 4.3 CPI's can be W and X
Simon
Old 06-07-2006, 07:04 AM
Exclamation Re: Ok, I got it ordered......now what.......
[quote=Junky1991]Is that the procedure for pre vortech 4.3ltr engines? I have the vortech engine so dont have the TBI, just that spider assembly.[/quote
gm service bulletin no:00-06-04-003B, file in section 06- engine/propulsion date- february 2003.
models: 1995-2002 chev and gmc s/t models
1996-2002 chev and gmc c/k, m/l, g, p models,
1996-2001 olds bravada
1999-2000 cad. escalade:
with4.3L, 5.0L or 5.7L(vins w,x,m,r-rpo's L35, LF6, L30, L31)
THIS BULLETIN IS BEING REVISED TO UPDATE THE CORRECTION AND WARRANTY INFORMATION. PLEASE DISCARD CORPORATE BULLETIN NO. 00-06-04-003A(SECTION 06- ENGINE)
This should be enough to google this bulletin no. and there are 2 methods for gm techs to follow, one is to clean, and the other is to upgrade from csfi(stock from factory for all these engines and models) Central sfi system to MFI, multi port flexible injection.
the bulletin was not a recall, and only the complaining customers during warranty ever heard of it. the procedure and the parts list for the conversion are still available from gm parts direct, or a gmc dealership. there is no aftermarket cross ref for the part no.'s in this bulletin, as i have been trying for 3 mo.' and no one even knows what i'm talking about.
as i was told, the conversion may or may nor help milage or performance, but remove a weak spot, and if the conversion is done right, there is one less thing to worry about for 4-5- years.
this will be my next engine upgrade, so if you are a wait and see type, i'll try to post before/after comentary.
Old 06-07-2006, 06:44 PM
[quote=excheezhead]
Yea someone needs to do this with full documentation and pics for us people that need step by step stuff. Keep us posted. Im just gonna replace this and hope it will last me awile, would like to drive this thing again, seems like it sits in my garage more than on the road, I guess in a way im keeping miles off it LOL.
Old 06-07-2006, 08:40 PM
this bulletin is on this forum, pdf file, under injectors or leaking injectors, or if you google the bulletin number, it actually has step by step instructions
Old 06-07-2006, 08:50 PM
blazee's Avatar
blazee blazee is offline
Problem?
Its for 96 up:
http://www.automotiveforums.com/vbul...d.php?t=542117
Old 06-07-2006, 09:29 PM
Ok, I got a burr up my butt and am trying to get the old kit off......I got the retaining clip off the spider assembly and am trying to get the torx bit off the back...I hate GM engineers right now. I bought a new torx bit set to get the T30 with a 3/8 adaptor, now thats missing in the engine somewhere. I also had a set that looked like a swiss army knife of torx, but I cant seem to get it between the fuel lines....im soooooooo frustrated right now...I dont even know if that torx is rounded...I really hope not.
Old 06-08-2006, 12:46 AM
Ok, if that torx was not rounded before it is now...im getting to the point were im about to take the spider assembly and poppets out and just do the whole fing thing because I never want to see the inside of a vortec engine again in my life. What is the best route to go now...should I take off the lower intake and drill out that torx or is there another way to do it. Id hate to take more stuff out, dont know if I can get what I have taken apart back together as it is.
Old 06-08-2006, 06:45 AM
the best way is to go to sears tool section and buy a set of screw outs. they look like backwards screw driver tip, and the other end is squared off like a tap/die set.(or they sometimes come in hex to fit drill drivers and hand tools) also know as easy outs, look for the ones that look sharp on the edges that will bite into the torx screw hole, and try that. if that does not work, and you have one of the other exact same sized torx bolt/screws, find a drill bit that is just a hair smallet the the bolt minus the threads, ie; you want to drill out the bolt, not the threads in the hole. then use a thread chaser to get the rest of the bolt in the threads. good luck, and i send my and not to be a a'hole, but this is exactly why ASE and long time shop mechanics charge so much for this kind of job. it's probably a 7-9 on the 1-10 scale of shadetree mechanic index. get er done man, your almost there
Old 06-10-2006, 02:54 PM
Cool man ill try that. Not gonna mess with it this weekend but maybe some sometime next week. Will keep ya posted and hopefully I can keep my blood pressure down lol.
