Old 05-28-2006, 09:27 PM
agco85 agco85 is offline
1991 F-150 won't start
I have a 1991 Ford F-150 with a 5.0 liter. The other day I went to start it and it wouldn't start, and I found I had no spark by testing it. I have checked the ignition module on the distributor, and I have replaced the electronic piece inside the distributor with a piece from a working distributor. I have also hooked up a different coil and condesor from a different engine, and my truck still won't start. Any suggestion would be appreciated.
Thanks in advance.
Old 06-16-2006, 01:32 PM
reree reree is offline
Re: 1991 F-150 won't start
Might be a bad distrubuator, mark it, take it out, have someone look at it, it must be put back in on the exact marks that you took it out.
Old 08-28-2006, 11:57 PM
17ford 17ford is offline
check for good connection at module and if your getting voltage at module
Old 08-31-2006, 06:52 PM
mrjlturner mrjlturner is offline
I'm having the same exact issues on my neighbor's 5.8 litre engine. We just replaced the coil & EEC module on the distributor today with no success. Here's the strange thing. We are getting spark when in the key "run" position, but when you turn the key to the "start" position to crank the engine, the spark stops. All electrical troubleshooting using manual has turned up positive without issue. Any further ideas?
Thanks!
Thanks in advance.
Old 08-31-2006, 09:15 PM
it might be something in the ign switch itself
Old 02-01-2007, 06:03 PM
Update: It turned out to be a shorted wire in the wiring harness. It took a mechanic about 3 weeks to find it.
...my 2 cents
Thanks!
Old 02-02-2007, 01:45 PM
FNA FNA is offline
It was not uncommon, (before the 91 model was when I was in business) for the ignition module, the electronic control unit itself to fail
Old 02-28-2007, 09:26 AM
wolf9304 wolf9304 is offline
yeah i kind off had the same problem mine was the ignition switch so i put in a push button to start my truck 88 ford f150 302 5.0
