| Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here. |
Can anyone tell me where the CPS on the 420A engine is located?
I removed most of the stuff to pull the timing cover from the block to look down inside for it (engine is not in vehicle), the only thing left to actually remove the timing cover is to remove the crank pulley/harmonic balancer. A diagram of its location would be great. thanks in advance! |
Re: CrankShaft Position Sensor
It's on the oil filter bracket on the backside of the engine. Be careful when taking it out because it breaks easily.
Go to dsm3d.com and download the engine illustration. |
Thanks.
I cannot get it to download. Keeps saying "The compressed (zipped) folder is invalid or corrupt." |
Talk to david_b about that. He was the one that made dsm3d.
where is the crank angle sensor on a 97 gst? thanks
1997 Eclipse GS-T Performance modification:-evo3 16g-K&N Intake-HKS SSQV b.o.v vented-2.5'' Dejon tool blow thru upper and lower-Dejon large smic-GM MAF-MAF Translator-HKS 3" Carbon Fiber Titanium TBE-stock fuel rail-Walbro 190 fuel pump-PE 650cc injectors-Accel Thundersport wires-NGK series 7 spark plugs-1g intake mani/head- Interior Modification:-Autometer Boost Gauge http://www.cardomain.com/id/xTeamRedLine23x |
Are you talking about the CPS (crankshaft position sensor) or the CAS (cam angle sensor?
Hey, my name is mentioned.
DSM3D.com took a hit awhile back. Sad, but I think it was a turbo guy. lol. j/k. Seriously though, if you lay down in front of the car and move back past the block, you will see the oil filter hanging down. Right above that on the side of the block is the CPS. It has an electrical connector on it. Kinda looks like a TPS from the side.
2013 Chevy Sonic 1LZ Daily Driver, 1.4L Turbo, 6spd 75 Monte Carlo SBC 400 6.6L, Aluminum heads, Hurricane Intake... 12 Chevy Sonic 1LZ 1.8L - Traded 01 Pontiac Grand Am SE - RIP 95 Eagle Talon ESi-T 5spd - RIP 88 Oldsmobile Cutlass Ciera- RIP |
So people can't download dsm3d anymore or what? Thank god I got it along time ago! haha. David, how's the turbo version coming along?
I found it, thanks
TeamRedline23 - On the GST 4G63 engine the Crank Sensor is next to the crank shaft under the timing belt cover - lot of work involved in changing it, from what I can see, in the 4G63 engines..... |
EDIT: I guess dksob beat me to it. Didn't see his post. |
thanks
