hey guys whats goin on? i have a 94 camaro z28 and while driving it the other day it started to make this klunck in the rear end. while excelerating in kluncks really loud and when i put the clutch in it still kluncks but not as loud. i was told it might be my gears but i have no idea please help me
Re: klunck in the rear
Could be bad bearing or a chipped tooth or a bad U-joint or some really old gross gear oil in there that lost viscosity.
Edit- Could also turn out to be a worn Tranny mount.
RIP Hypsi - I just want to express I will never be the same after having lost such a good friend. You meant alot to me and I feel I am a better person for having known you. Til the day we meet again my friend you will always be in my heart. Mods: Weight reduction (I don't wear underwear) |
i checked the rear fluide and i just put in a brand new tranny mount i think it may be my gears in the rear but sumone told me that when gears go they dont klunck.
Depends on what you mean by "go". Generally a ring gear or pinion gear with chip a tooth on a weak point. Then it can whine or clunk depending on how severe or what part of the gear tooth is damaged.
is the noise consistent with speed at all?
1984 Camaro 5.7L 350 700R4 Holley 650 Cfm Edelbrock Performer Intake-Manifold Crane Cams Duration @ .050": 204/214 Lift:420/442 Summit HEI Distributor Hedman Shorty Headers Hedman Y-pipe Dynomax Turbo cat-back NOS Decal VTEC Decal |
now that u bring it up, the rear was humming before it started to klunck.and the klunck goes faster the faster u go.but as soon as u let off the klunck mellows out and when u give it gas it comes bac again
Pinion bearing & seal
If the gears have been recently swapped Pinion bearing is very likely as most shops just use a Impact gun rather than a torque wrench like your suppose to.
