Go Back   Automotive Forums Car Chat > Mercury > Cougar
Old 05-28-2006, 12:17 PM
jeclair jeclair is offline
95 cougar shifting problem
Grandfather has a 95 cougar that has always been taken care of very well, but lately while going down road @ 55-60 mph transmission will down shift like it is going up a hill. This will happen going on a flat road or going down a hill. My question is " does cougars have a module for shifting or is it vacuum? I don't know much about Mercury so any help will be nice. Thanks....John
Old 05-29-2006, 01:32 PM
samturner samturner is offline
Re: 95 cougar shifting problem
Doubt this is whats wrong with yours but I have a 91' with a 3.8 engine and off the throttle body the top lever I think is controled by the gas pedal. Below that is a cable connected to the bottom of the throttle body and I think this is controls smooth shifting, anyway it goes to the transmision. It had came unhooked and caused various shifting problems. I replaced the thing that connects it and the transmision works fine now.
Old 06-06-2006, 05:11 AM
C. Cleve C. Cleve is offline
Hi, RE, Your shift problem with the cougar, Get me some info and I can probably help,,,,,I need the build date(on the door decal), The engine size, and the trans type, AODE or 4R70W ? There are numerous ford TSB's on these problems, I need the info to help you,,,SEE YA, Clay..
Old 06-20-2006, 11:09 PM
vtwindave vtwindave is offline
Smile Re: 95 cougar shifting problem
change the "range sensor" that used to be called manual lever position sensor. it's located where the cable attaches to the shift lever on the left side of tranny, it has a electrical connector plugged into it. that will fix problem, had the same problem.
