Old 07-27-2002, 08:21 PM
robertc robertc is offline
half open window rattle
My 91 Civic HB driver-door glass rattles when half open or more. I found a TSB number & date (91-010, 4/12/91) on my old AllDATA cd for this condition but no repair info was given. Anyone know about this & recommend a fix? Thanks!
Old 07-27-2002, 09:34 PM
Melt's Avatar
Melt Melt is offline
Send a message via AIM to Melt
try taking your door panel off and tightening shit down, thats what I did in my old car when it started to do that.
AF Bay Area Crew
97 Toyota T100 xcab 3.4l v6 5spd 2wd
Old 07-27-2002, 09:43 PM
gunnmen01's Avatar
gunnmen01 gunnmen01 is offline
Send a message via AIM to gunnmen01 Send a message via Yahoo to gunnmen01
With that service bulletin # i should be able to look it up at work and see if there was a repair for it....I'm a honda mechanic.
gunnmen01
My other ride..... is YOUR MOM !!!!!!
Old 07-28-2002, 01:20 AM
Gunnman01, thanks for doing that! I seem to remember coming across that TSB showing a recommended repair long ago but can't find it now. Hope ya find something- that would be great & appreciated!
Old 07-31-2002, 02:17 AM
BullShifter's Avatar
Exclamation
First I'd R/R the door panel to tighen things up. Then check on the window run chanel. I will look the bulletin # @ work. I'll report back with something tomorrow.
honda service advisor
Old 07-31-2002, 03:21 AM
Ebranste Ebranste is offline
Send a message via ICQ to Ebranste Send a message via AIM to Ebranste
Here's an idea. What I've seen alot is people who have had to replace their windows fro whatever reason........car got broken into being the most common.
For whatever reason, most of the time the replacement piece of glass is half as thick as the stock glass which of course causes somewhat of a problem.
This may not be true in your case, but I've seen this happen to some people and they wonder what the problem is.....which is why I will always pay hte extra $50 for the stock Honda glass or get it from a junkyard.
Old 07-31-2002, 06:29 PM
It's original glass. There's a TSB out there showing how Honda recommends fixing this apparently common problem with the door glass & before attempting to fix it myself I'd like to see what their recommended fix is. The TSB I saw long ago showed a diaghram on how to repair it. Thanks for your help, though!
Old 08-01-2002, 01:58 AM
I checked the bulletin out at work today. Its for Accords & Preludes.
I also asked the shop foreman, he said hit the middle of the window with a hammer. No window No rattle
Old 08-06-2002, 01:37 AM
91-010 is for Accords & Preludes - i will bring a copy home & send you a copy so you can see it.
