Old 05-27-2006, 06:41 PM
geodone geodone is offline
road noise
I have a 98 cavalier z24 that makes a humming noise while driving down the road. It seems like the noise is there at all speeds but gets louder with speed. If you turn the steering wheel to the right the noise stops. I hit a telephone pole on the right side and it made this noise since. I have replaced the right side axle and hub. Anyone have any other ideas. Thanks in advance.
Old 05-28-2006, 07:23 AM
OverAllComa OverAllComa is offline
Send a message via AIM to OverAllComa
Re: road noise
Telephone pole? Control Arms might be bent, Tie rods might be screwed up, might've bent the frame. Who knows, could be lots of stuff.
1992 Chevrolet Cavalier Z24 *R.I.P.*
3.1L MPFI (3.1 6cylinder Pushrod 12V)
1997 Chevrolet Cavalier Z24 *R.I.P.*
2.4L "Twin Cam" (2.4 4cylinder DOHC 16V)
2003 Honda Accord EX V6 - The new hotness
Old 05-28-2006, 02:51 PM
Re: road noise
I didnt hit the pole that hard to bend the frame, but I did take it to have it aligned afterward and they told me the alignment was pretty far off. Is there any way to check the tie rod and control arm. I already have $150 and several hours of labor into this without any improvement.
Old 05-28-2006, 06:28 PM
94VL 94VL is offline
Re: road noise
Bent control arm,bent subframe rail,or tweaked strut tower.Your tires arent tracking correctly,and I bet that noise is the tread of the tires being dragged across the pavement.Betcha lots of tire wear....
