Go Back   Automotive Forums Car Chat > Lincoln > LS | MKZ
Old 05-27-2006, 03:52 PM
jsciorti jsciorti is offline
Send a message via Skype™ to jsciorti
2000 ls code
what is the code for 1299 and what do i i do to fix it
Old 05-27-2006, 04:39 PM
clubairth clubairth is offline
Re: 2000 ls code
The 1299 code is "Cylinder Head Over Temperature Protection Active". This means the car thinks it's overheating and should go into "fail safe" mode.
You really are going to have to come up with a better description or we can’t help?
Old 05-27-2006, 04:59 PM
shorod's Avatar
shorod shorod is offline
SHO No Mo
Re: 2000 ls code
As clubairth mentioned, powertrain troublecode P1299 (per the Ford Service Manual):
Indicates an engine overheat condition was detected by the cylinder head temperature (CHT) sensor. An FMEM Strategy called Fail-safe Cooling was activated to cool the engine.
Possible causes:
  • Engine cooling system concerns
  • Low engine coolant level
  • Base engine concerns
If you'd like a PDF copy of the FSM troubleshooting steps, private message me with an e-mail address for you that can accept PDF attachements and I'll e-mail it to you.
-Rod
Old 05-31-2006, 01:43 PM
Re: 2000 ls code
[email protected] thanks again if there is anything i can do for you let me no
