Go Back   Automotive Forums Car Chat > Mazda > B-Series/Bravo/Bounty/Drifter
B-Series/Bravo/Bounty/Drifter Bravo is the Australian vesion, Bounty the New Zealand version and Drifter the South African version.
Old 05-27-2006, 01:02 PM
davemoore29730 davemoore29730 is offline
brake lights HELP!!!!
hey i lost all of my brale lights ...the other lights do their job but when i step on the brakes nothing.....even on the cab light ....i dont see any fuses that are blown or maybe am looking at the wrong ones.also have replaced the switch on the brake peddle and still nothing ....any ideas?
Old 05-28-2006, 09:16 AM
hocbj23 hocbj23 is offline
Re: brake lights HELP!!!!
All the wiring for the rear lites exits the truck at the bottom of the cab in the rear.Check it to be sure that no wires are cut or frayed.Also check bulb,would be rare for all to fail at once but could happen.BJ
Old 06-03-2006, 10:03 PM
mazdaman26i mazdaman26i is offline
you might want to check the wires going to the rear to the back of the lights they could be corroded or chaffed wich would cause them to do so
Old 06-06-2006, 01:21 PM
Cusser's Avatar
Cusser Cusser is offline
check electrical switch on brake pedal.
Old 06-06-2006, 02:05 PM
1st post on thread said he replaced brake pedal switch. BJ
Old 06-06-2006, 02:41 PM
Cusser's Avatar
Ever get a malfunctioning part or item in a new box, if not, you're lucky. He still needs to check the new switch (with ignition switched on) - using a test light or voltmeter - that he gets 12 volts positive on one side of the switch, then gets 12 volts positive on the other side as well when the brake pedal is pushed down. If he doesn't get any 12 volt positive to the switch, he needs to work backward, like checking the fuse, need to consider the circuit like water in a hose, need to find to find the reason the current is not flowing to the switch on the pedal then. If current passes through the pedal when pushed down, then check for current at the brake light bulbs with the test light or voltmeter. Also make sure the light fixture makes good ground contact. Also check any in-line wire connectors, especially if someone has sometime jury-rigged up trailer connections. There likely is a multi-wire light connector under the truck bed. Hell, bring it to Arizona, I'll fix it !!!
Old 06-23-2006, 03:28 PM
ok i feel like an ass. I checked the bulb in the over the cab light and it was blown. went out and got a new one and now they all work!. who would have believed that they would wire the brake lights in series????!!!!! thanks for all your help on this and i will reccomend yall and be back......thanks a gain !!!!
Old 06-23-2006, 03:46 PM
Even stranger than that-the automatic tranny Mazda pickups have the tranny lock mechanism wired into the same circuit so if your dome lite or brake lites blow, u cant get the truck in gear with out using the emergency override.Weird. Glad u got ur ride fixed. BJ
Old 06-23-2006, 03:51 PM
thats GREAT!!!!!!!!!!! if that happens where is that located?
Old 06-24-2006, 11:19 AM
On the drivers side of the tranny shift lever "box" in the cab of the truck there is a small square "plate" with a small slot at the top. Open that with your nail or a small screwdriver and inside is a red lever that you can push to free your tranny shift lever iuntil u get ur lights ar fuses replaced.When u get the blown light or fuse replaced the lever snaps back into the off position by itself. BJ
