Go Back   Automotive Forums Car Chat > Mazda > RX-7
Old 05-27-2006, 12:37 PM
fb33112arx7 fb33112arx7 is offline
cold start assist
Does anybody know what I could put in the tank of my sub-zero start assist? Possibly with a switch to use it whenever I want.
Old 05-27-2006, 08:26 PM
Capt.Moe Capt.Moe is offline
Send a message via MSN to Capt.Moe
Re: cold start assist
it's a 90/10 mix antifreeze and water... as for a swtich to use it I don't know?!
Old 06-09-2006, 11:04 AM
ude_loose's Avatar
ude_loose ude_loose is offline
Send a message via Yahoo to ude_loose
I doubt you can use a swicth to use it...
Old 06-09-2006, 11:50 AM
I meant something like ether only liquid, to help me start my car from the cab easier. Why can't I hook up a switch to it?
Old 06-09-2006, 09:21 PM
ude_loose's Avatar
well with the start assist you just have to put the mix into the little tank and when ever it is needed it will be used...
Old 06-10-2006, 01:04 PM
Dude, I meant using it for a different purpose than it is intended for.
Old 06-10-2006, 07:05 PM
ude_loose's Avatar
ohh my bad man, so like what do you plan to use it for...
Old 06-11-2006, 01:51 PM
just assisting with starting. Basically I want it to work similar to spraying ether in the carb, only remotely operated so I don't have to pop the hood. I am starting to think this is just stupid, and I should fix the problem thats causing the hard starting instead of just treating the symptoms.
