Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 05-26-2006, 08:32 PM
ruben95365 ruben95365 is offline
need help with 93 Rodeo Izusu Regulators for Windows V6 3.2
Hi Guys,
New to this and I can sure use some help with A window regulator on passenger side back...I did find a very good schematic on how to remove windows and replace regulator(s) (took my off in 10 min)....if needed let me know and I will post somehow. My deal is this..the plastic pully that the cable rides on broke,everything else is working fine... motor, cables,... dealer wants first born...any suggestions on where or how to buid or buy that pully? Also, their were manuals posted at one time for 93 Rodeo Izusu does anyone have that they can send me?
Thanks In Advance for any reply's
Old 05-26-2006, 09:21 PM
surferfletch surferfletch is offline
Re: need help with 93 Rodeo Izusu Regulators for Windows V6 3.2
I find that if the cable gets off the pulley, it gets spooled incorrectly and it's less hastle to get a cheap regulator online and replace it. I'm sure I've posted a link before...
Old 05-27-2006, 10:49 PM
FIXED PROBLEM.
Well, I got it done! but,....my cable is loose... I got the window to go up and down but it laggs because of too much slack in cable. I've seen the pics that are posted on a 95 and it looks different or does anyone know or have any instructions on how to re-roll cable. I don't mind removeing everything again....I'm an expert now...
Old 12-26-2006, 02:44 AM
explicit408 explicit408 is offline
Bump.
Any updates? My rear windows just gave out and I think the front passenger is on its way. It takes forever to go back up.
Old 12-26-2006, 07:25 AM
Ramblin Fever Ramblin Fever is offline
Have the same issue on my front drivers window - specially if it's cold or humid outside.
I'll get into it at some point, for now it's still working just very aggravating
1997 3.2L V6 Rodeo
32" Yoko's, 16x8 MB Wheels, 2" lift, Brushguard, KC Fog's, Loadwarrior Rack
On it's way to 185k strong
2004 3.4L Tacoma TRD off-road 4x4 Double cab
32" Yoko's, Westin Bull-bar, KC Fogs 60K miles
Old 12-28-2006, 10:53 PM
660Ryder 660Ryder is offline
Just fixed the same problem yesterday morning...
Window was stuck and not moving - disassembled the door and found that the upper guide had snapped, causing the two cables to bind and not allow any movement. Wanting a quick fix and being a capable "ham-and-egger", I drilled a hole straight through the door and into the metal strip the window moves on. I then cut a bolt to size and filed out a notch to act as a makeshift guide. Reassembled and works good as new. I just need to remember that fix and not use the window too much so as to not fray the cable. I couldn't figure out how to remove the cables/guides/metal strip, otherwise I would have picked one up at the junkyard or fashioned a new one myself.
Was going to do the thermostat as well - but have no idea how to go about it - darn thing is hidden underneath too much for me to attempt it.
Old 12-29-2006, 07:49 AM
Originally Posted by explicit408
Bump.
Well I will try to find all the paper work and pics to send you.....the plastic pully on top busted so I went down to OSH bought a plastic pully and jerry rigger it!!! the hard part is taking out the window....once that is done? it is all down hill from there. I will look and post or e-mail them to you.
Ruben.
