Old 05-26-2006, 05:10 PM
anthony90si anthony90si is offline
brake pad problem
ok i just changed all the front brakes(rotor,caliper, pads)and the pads don't touch 100% on the rotor.(as if the pads are not square with the rotor.) looks liek i put everthign on fine. not many places to go wrong with calipers. anyone know what the problem might be. oh and both sides are the same(prob something i did wrong)
thanks
stock b18a1 14.97 @ 92 mph
Old 05-27-2006, 05:50 AM
Jos4DCivic's Avatar
Jos4DCivic Jos4DCivic is offline
Send a message via AIM to Jos4DCivic
Re: brake pad problem
what you mean they dont touch 100%? where calipers marked Right/Left? Can you get a pic of what you are talking bout?
91 Hatch SI
Heart of my Baby - DOHC ZC - Si tranny - PG7
Finally painted!!!
Old 05-27-2006, 11:29 AM
FrodoGT's Avatar
FrodoGT FrodoGT is offline
He means the pads are hitting the rotors at an angle and not making full even contact.
Cheap, Fast, Reliable..Pick two
Current project:
Rio Red 91 hatch.
A6/Z6 build, Hondata S300, Tokico illumina/Ground Control.
"I'd rather run 12's on steelies than 15's on rotas."
Old 05-28-2006, 04:14 PM
ya exactly! it is kinda inpossible to install the calipers on the wrong side
Old 05-29-2006, 08:43 PM
any one have an idea?
Old 05-30-2006, 11:27 PM
civic_boy91's Avatar
civic_boy91 civic_boy91 is offline
Send a message via AIM to civic_boy91 Send a message via Yahoo to civic_boy91
did you put the pads on upsidedown....it really wont go back togather wrong...
_________________________________http://VelocityFactor.com________________________________
1990 si hatch
b20b si tranny
megan race header 2.5 custom exhaust
50 shot
integra da rear disk (w/ 4040 valve)
powerslot rotors and barded lines all around
1994 Dx hatch
stock
Old 05-31-2006, 12:56 AM
FrodoGT's Avatar
Dude, youd be more likely to put them on the wrong side then to put em in upside down..being that it is impossible! I cant even imagine them fitting that way...
Current project:
Rio Red 91 hatch.
Old 05-31-2006, 06:47 PM
ya for sure, i am sure they are on the right side and for sure not upside down. the only thing that i could see is that i didn't use and shims. are they nesesary casue the old pads had some.
Old 06-01-2006, 03:10 AM
Jos4DCivic's Avatar
get a picture.
91 Hatch SI
Finally painted!!!
Old 06-01-2006, 03:16 AM
YZ125rider21's Avatar
YZ125rider21 YZ125rider21 is offline
Send a message via AIM to YZ125rider21 Send a message via Yahoo to YZ125rider21
Originally Posted by Jos4DCivic
get a picture.
beat me to it mate haha...need picssssssssss
90 Honda CRX Si
-Red/Black
-B20B/b16
-AEM CAI -/\- Apexi GT Header/2¼" Custom Dynomax Exhaust
-Tein SS CoilOvers with pillow ball monuts -/\- ST Swaybars/Energy Suspension Bushings
-16x7 Lightweight Rotas -/\- Pro Stop Rotors -/\- Goodridge S.S. Brake Lines
-Skunk2 Shifter -/\- MoMo Steering Wheel
Old 06-02-2006, 02:45 PM
johnb16a2's Avatar
johnb16a2 johnb16a2 is offline
Check your caliper slide pins, they're probably dried and/or rusted. GL A picture would help... j/k
Old 06-03-2006, 03:57 AM
lol. everthing is new calipers sliders and all. ya pics but i don't think that you can see much with a pic, its hundreds of and inch we are talking about here.but i will try to figure out soemthing for a pic. thanks
Old 06-03-2006, 10:56 AM
Smoghog Smoghog is offline
thanks
How did the old pads look, Did they display the same angles?
If it is only hundreth's of an inch it might be designed into the calipers, Maybe to minimumize sweaking.(spelling)sorry!
Also did you use anti sweak on the back of the pads? You said you didn't use the shims, may I ask why? They were designed for them!
I hope you got the correct calipers
Old 06-03-2006, 05:18 PM
ya the oild pads that had the shims had the same wear. and yes the calipers are the right ones. i didn't use the shims cause the old ones were worn out and the new pads didn't come with any so i didn't think it was nesessary.i guess they are more nesessary then i thought
