Go Back   Automotive Forums Car Chat > Pontiac > Bonneville
Old 05-26-2006, 04:47 PM
1987ss's Avatar
1987ss 1987ss is offline
car hesitates
1992 se.. it started hesitating when it was kicked down on freeway today at 70 mph.. and at 1-50 mph it wasnt doing it... but now its doing it at all speeds.. it almost like when your fuel is low and you take a corner and accelerate how it hesitates due to lack of fuel no check engine light comes on i recently changed plugs,oil ,pcv,air filter and, fuel filter.. like 300 miles ago.. any help will be appreciated.. oh yeh it did it like a week ago when it was warm out i dont no if temp can play a part in it.... and if you put accelrator to floor motor rpms dont even go up it acts like its goig to stall...
I just put a scanner on it and codes 22 throttle position sensor- low voltage
38 brake switch circut
36 ? i dont know??
And scanner said trans shift problem PLEASE HELP!!!!!!!!!
Old 05-27-2006, 07:06 PM
1987ss's Avatar
Re: car hesitates
ANYBODY?
Old 05-28-2006, 10:59 PM
1987ss's Avatar
Re: car hesitates
no suggestions???
Old 05-29-2006, 11:38 AM
maxwedge maxwedge is offline
A990 racer
Re: car hesitates
Originally Posted by 1987ss
no suggestions???
Check fuel pressure, especially under load, if low replace fuel filter and recheck. Sounds like a bad tps, to be sure a graphing scanner is called for here or take a shot and replace it. Post the trans codes, which can be caused by a tps.
Old 05-29-2006, 01:02 PM
1987ss's Avatar
Re: car hesitates
thanks i appreciate the feed back!!!! i just chanded the fuel filter should i do it again? and last time i scanded it the tps was reading low....
Thank you
Old 05-29-2006, 01:52 PM
A990 racer
Re: car hesitates
Recheck fp, as I said. The code said it was low?
Old 05-30-2006, 11:08 AM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
Re: car hesitates
I agree with Max, the TPS could trip the trans codes (and the others for that matter). Code 36 is MAF burn-off circuit (which I've never heard of). If you haven't checked fuel pressure (again, as Max suggested) or changed the TPS, until you do, we can't help you any further.
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
Old 06-04-2006, 12:01 AM
1987ss's Avatar
Re: car hesitates
thank you im a get to it this week
Old 06-05-2006, 09:34 PM
Malachias Malachias is offline
Re: car hesitates
36 ? i dont know??
Did you check your fuel pump pressure?
Sounds like you have a bad pump!!!!
Malachias (BRASIL)
Old 06-12-2006, 01:35 AM
1987ss's Avatar
Re: car hesitates
Malachias (BRASIL)
it only messes up when vechile is at operating temp for about 1/2 hour.. can a fuel pump do that and work intermittenly?
Old 06-12-2006, 10:42 PM
Re: car hesitates
The answer to your ask is YES.
Malachias (Brasil)
Old 06-14-2006, 10:33 PM
1987ss's Avatar
Re: car hesitates
didnt get to fix it went to drive it to a buddys and it has alll of the above problems and a new one now it stalled at stop. so i brought it back home and parked it it started right back up both times.. i dont no if its a new issue or realted to the other...
Old 06-30-2006, 12:29 AM
1987ss's Avatar
Re: car hesitates
does anyone know the specs to set a new tps sensor?
Old 07-07-2006, 02:03 PM
1987ss's Avatar
Re: car hesitates
i changed tps today and cleaned out throttle body.. it still hesitates after it gets hot and you wot it or kick it down... any ideas please help
Old 07-07-2006, 10:23 PM
Re: car hesitates
CHECK YOUR FUEL PUMP!
Malachias (Brasil)
