Old 07-27-2002, 01:37 AM
coonass420 coonass420 is offline
Send a message via AIM to coonass420
Unhappy B16a questions
I got my motor in off the truck yesterday (B16a). It is going into my 1991 CRX Si. It looks to be in relitively good shape. except i did notice a couple of things.i think there maybe a peice missing where my tranny and block meet because i think i saw my flywheel. Is this trouble or just cable tranny? the other question is on the axeles, the boots are all torn up does anybody know what kind of boots i would look up to replace them with.
Old 07-27-2002, 01:45 AM
BigBearWest's Avatar
BigBearWest BigBearWest is offline
WWW.CalgarysFinest.COM
Send a message via ICQ to BigBearWest Send a message via AIM to BigBearWest Send a message via MSN to BigBearWest
Talking
about the boots. u can get them in any parts store. they should be 87-89 teg axle boots
Old 07-27-2002, 11:36 PM
5_LiTeR_EaTeR 5_LiTeR_EaTeR is offline
Send a message via AIM to 5_LiTeR_EaTeR
as for the flywheel you can see it 3 ways. Either your gearbox is loose and you are seeing between the block and the tranny, your starter is missing or the obvious there is no inspection cover on the bottom of the transmission. Honda did not make an inspection cover for the b16a's for some reason I think its sorta stupid actually. But most of the hondas I have worked on do not have an inspection cover.
VTEC WORKING FINALLY & HAULIN SOME ASS!!
If the shadow of your car is smokin' you it definately means you are smokin' someone else!!
KKK k24 Turbo on the way to the install!
Old 08-08-2002, 02:26 PM
EF You's Avatar
EF You EF You is offline
EF Life Giver
Send a message via AIM to EF You
my b16 has an inspection cover. also, by the look of your screenname, i would imagine you are from somewhere in the south, maybe louisiana? if so, i just put a b16 into my very ugly 4g hatch. PM me if you are anywhere near new orleans, and ill be glad to help you with the swap.
Old 08-09-2002, 10:21 AM
mellowboy's Avatar
mellowboy mellowboy is offline
Amy dragged me here...
Send a message via Skype™ to mellowboy
Maybe it didn't come with a tranny?
