Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 05-26-2006, 10:36 AM
dkitty dkitty is offline
Question new problem.. power steering?
You might remember me, I was the one wil the 1996 eagle talon ESI (non turb0, 4 -cyl, 2.0 L) that was having the stalling problem afew months ago. It turned out to be a falty O2 sensor and a ton of carbon buildup. That's fixed but now it's somehting new.
I know my new issue has to do with the power steering. I start up the car. Fine, Until i turn the wheel. It makes the typical ear piercing screetch associated with a dying PS system.. but the strange thing is, when you look under the hood, the belt actually stops turning when the wheel is moved (moved quite a bit.. as if to turn out of a tight parking space). It only does this for really sharp turns. Is this the pump? A bearing maybe? I'm clueless. Also, it tends to be much worse for the first 5 mins, but get a tad better once the car warms up. It never goes away completely.
Problem #2 may or may not be related. Whenever i move the wheel just a bit (the high pitched squeeking is only during sharper turns.. as to get in/out of a parking space.. the low groan is when i turn the wheel only slightly.) there is a low croaking groan. It's only when i move the wheel slightly in one direction or another. It sounds like a dying rinocerous, just a loud deap creaking noise. It dosen't seem to affect the proformance of the turns, it's just very loud and grating. The powe steering well is full, and there are no leaks in the system. I don't know what it could be.
Any ideas? These two are likely related, i'm thinking. Symptom #1 started first, then symptom #2 came afew weeks later. I would appriciate any advice or where i should start with this.
Thanks so much!
-syn
Old 05-26-2006, 04:54 PM
ITSME4G63 ITSME4G63 is offline
Send a message via Yahoo to ITSME4G63
Re: new problem.. power steering?
maybe the pump is dead? If it was locked up the belt wouldnt prolly spin at all or it not fully locked up?
Old 05-27-2006, 01:16 AM
defiancy's Avatar
defiancy defiancy is offline
Stay classy San Diego
Thanks so much!
-syn
Replace your power steering pump. If you turn the wheel and the pulley is seized that is a good indication that the pump is done.
1991 GSX 2.3 Stroker
Old 05-27-2006, 08:45 PM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
The pump probably ran dry and locked up, or just locked up, which is causing your problem. Replace the PS pump.
95 Talon TSI AWD
97 Eclipse GST
Old 05-28-2006, 02:46 AM
ez1286's Avatar
ez1286 ez1286 is offline
Send a message via AIM to ez1286
The belt stops turning when you turn the wheel sharply because it creates a load on the pump. Your best bet it to fix the first problem with a new power steering pump (and belt, cause that belt has been seeing too much friction!) and hope that also solves the groaning problem.
95 GSX:FMIC, 6-bolt, evo 3 16g, 2600 act clutch, 1g bov (crushed), and a 3" turbo back exhaust, dsmlink, dks 272 cams, wideband 02, Coming soon 2.3L Stroker, 1mm oversized valves, crower sprigs. 91 TSI AWD auto, gm 3.5 maf, maft, fmic, emanage, profec e-01, 3" turbo bk exhaust +more little stuff.
http://www.ratemydsm.com/member/ez1286/?member=ez1286
