Go Back   Automotive Forums Car Chat > Honda > Civic | CRX > '71-'87 Civic | CRX
Old 05-26-2006, 10:08 AM
Deadboy's Avatar
Deadboy Deadboy is offline
Send a message via MSN to Deadboy
Need help finding a part for 87 ZC
Got A 87 ZC that was missing a TW sensot (thermosensor). Showed the pic and told the shops the name ...but no one dident have it + the manual does not show it that well. Maybe some one can take a pic of the sensor or even better tell me the code thats on the sensor
Here a pic were the sensor should be ( it should be bigger then the 88-91 ones)
Old 05-26-2006, 01:47 PM
lxndr's Avatar
lxndr lxndr is offline
AF -Advisor
Re: Need help finding a part for 87 ZC
The one in my spare '87 D16A1 head only says "5E", I don't think this is the part number. I can't get close enough to the one in my '89 head to see what it says.
When I replaced my TW sensor, no one had a clue what I was talking about until I called it a "coolant temp sensor", then described it as the sensor that sends the coolant temp signal to the ECU. Moments later I handed them $35 (USD) and was walking out the door with the part I needed.
Old 05-26-2006, 03:10 PM
Deadboy's Avatar
Well i showed a pic from the manual were it goes and told the guy that i should be the sensor that controls the Idle of the engine....should be that.
found this:http://oem.thepartsbin.com/parts/the...Sensor&dp=true
Gone show that to the shop......they had a catalog with pics so maybe it will help
Old 05-26-2006, 07:30 PM
lxndr's Avatar
AF -Advisor
Yes, it helps control the engine idle.
The ECU reads the signal form this sensor and when the engine reaches normal operating temperature, the ECU sends a signal to close the EACV/IACV which brings the idle down to normal.
BTW, mine looks exactly like the one pictured at the top of your link.
