Old 05-26-2006, 09:39 AM
cordovaass's Avatar
cordovaass cordovaass is offline
Send a message via AIM to cordovaass
ideas for saving gas
im looking for the best ways to save at the pump. my truck has the K&N intake system that i just cleaned and used just a little bit of oil this time. i cleaned my maf sensor. i have flowmaster exhaste. i have a new fuel filter. im changing my spart plugs on saturday. any suggestions on what plugs to get? is 8 bucks a pop for bosch platinum 4 worth it?
SLAMMED! 4 inches in front 8 inches in rear
Custom pipes with flowmaster 50 series delta flow
K&N intake system
Caddilac door handles
Caddilac gauges
Pioneer cd player
Shaved moldings and emblems
Old 05-26-2006, 10:51 AM
wrparks wrparks is offline
Re: ideas for saving gas
Honestly, I'd put right back in what came in it from the factory. Just seems to work best 95% of the time. I've had bad experience with bosch plugs in both a blazer and saturn and will not buy them again, but others love them. It's relatively cheap, buy some and give it a try. At the worst, you'll have to buy more and put them in later. Honestly, I like AC Delco and stick to it. The factory has done the testing and if it is good enough for them it's good enough for me.
Old 05-26-2006, 11:17 AM
SLJ2137694 SLJ2137694 is offline
You might want to consider synthetic lubricants. You probably already have a synthetic rear differential lube from the factory, ask your dealer about that. Next oil change try Mobil 1 for the engine. Your owners manual probably recommends 5W-30. When I went to synthetics in my 92 Chev 4X4 in both differentials and engine, I gained at least 1 MPG. Your gain may be difficult to measure but you can also be assured your truck is benefiting from a better lube. See www.Mobil1.com for additional info.
Old 05-26-2006, 05:31 PM
silveradoHO silveradoHO is offline
I wouldn't use the Bosch platinum 4. Even though there are 4 tips, only one fires at any given time, which is the same as any other plug. AC Delco works as good as any.
Old 05-26-2006, 08:16 PM
cordovaass's Avatar
i have synthetic blend in the motor, i just canged my oil less than a month ago. your right i should change the diff oil too.
K&N intake system
Caddilac gauges
Pioneer cd player
Old 05-27-2006, 04:19 PM
My 2005 Silverado came with synthetic in the rear differential and yours may already have it too. Ask your dealer what is in it before you just go and change it.
Old 05-27-2006, 04:42 PM
skipr skipr is offline
I'm not saying synthetic blend formulas are bad, A "BLEND" meaning it's not true synthectic like Mobil 1. It is a blend of hydrocarbon oil stock, it could be group 1, 2, or 3 base stock. Then poly oil base stocks are blended. The problem is you don't know the percentage, which can be 80/20 50/50...etc. 100% synthetic is true polyaphaofins.Amsoil and Mobil 1 are the most reconnized true synthetics using POA's (not ester oils, mineral oils,hydrocarbon based syn.) They is no set standard by the API which states how much POA's must be blended to make them claim it's synthectic. It can be 10% POA to 90% group 2 or 3 (the higher # the better grade crude stocks).
Old 05-28-2006, 12:22 AM
Tdragone Tdragone is offline
Make sure your tire pressure is correct. Driving on low pressure tires can create a LOT of rolling resistance.
Old 05-29-2006, 01:52 PM
gremlin96 gremlin96 is offline
do all your shoping in one trip for the week.
stay off the brakes. i see a lot of ppl riding there brakes. on going down hill just let the truck roll. the rpms will drop and you can just take the next one with the speed you build up.
Old 05-29-2006, 02:17 PM
korndogg's Avatar
korndogg korndogg is offline
Send a message via AIM to korndogg Send a message via MSN to korndogg Send a message via Yahoo to korndogg
you dont need to ask the dealer. If its synthetic, there will be a plate on the passenger top of the diff that states it needs synthetic. At least its on my truck.
1968 Camaro 327
1999 Silverado 1500 Z71 LT
{o,o}
|)__)
O RLY?
http://www.cardomain.com/id/korndogg002
