Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 05-26-2006, 04:26 AM
capriceforever's Avatar
capriceforever capriceforever is offline
Right Gasket Sealer for Intake Manifold
I'm replacing the tin splashpan intake manifold gasket on my 1990 caprice with the Olds 307 engine. I've got some conflicting information hopefully someone can clear up for me.
My shop manual says to use Silicone RTV on the front and back of the block, and a aviation grade sealer around the ports. (capable of resisiting fuel vapors)
The Felpro gasket kit however comes with Silicone RTV, and says to apply that on the corners of the block only, (comes with composite strips for front and back of block), and the kit says to apply Silicone RTV around the water ports only on the intake gasket. But nothing around the exhaust ports.
So should I apply silicone RTV around the water ports, and then aviation grade permatex around the exhaust ports, or can I do like my shop manual says and just use aviation grade permatex around all ports, water and exhaust?
Really want to get it right the first time!
Thanks
Old 05-26-2006, 05:30 AM
Nym's Avatar
Nym Nym is offline
Re: Right Gasket Sealer for Intake Manifold
I have always used a silicone based RTV sealant on intake gaskets and nothing on the exhaust side. Come to think of it, I can't think of ANYBODY who has used sealant on exhaust ports..........
Good luck
PS: I don't even like using those friggin rubber end gaskets. I've always laid down a nice bead of RTV in their place. no troubles to date (touch wood). My two cents worth....
Insert intelligent quote here
1994 Caprice Classic station wagon LT1
1989 Olds Cutlass Ciera
Old 05-26-2006, 10:37 AM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
Use just the "valley pan" gasket for the intake itself. On the end seals, you can use RTV. Personally, I use a sealer called "The Right Stuff" by Permatex. This stuff I've yet to see leak, and you don't have to wait for it to set up - as soon as you bolt it together it can be used.
Don't RTV the intake mating surfaces on the heads or manifold - gasoline will over time attack the RTV and cause problems. Use Permatex #1.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
Old 05-26-2006, 11:48 AM
1986Z28's Avatar
1986Z28 1986Z28 is offline
Has a Camaro
Send a message via MSN to 1986Z28
i use rtv only on the end gaskets
Formerly Blownalcoholboy
1986 Z28, 400ci SBC, Twin borg warner billet S467 turbos, Reid case powerglide, Moser 9". Holley EFI, Boost Leash. 950RWHP on pump gas, 1200rwhp on race gas (22 psi)
Best ET 1/4: 8.35 @ 170mph (275 drag radial)
Best ET 1/8: 5.44 @ 132mph (275 drag radial)
Best 60': 1.31 on the back tires (275 drag radial)
AF User Rules/Guidelines
http://www.automotiveforums.com/vbul...uidelines.html
Old 06-19-2006, 05:03 PM
easterwabbit easterwabbit is offline
yes black RTV across top front and rear of the block, and sometimes i will also go around with a thin coat of it around the water port and each end of the intake gaskets, but not on all engines, it just depends on the condition of the gasket surfaces of the heads and intake, if they are corroded pitted then i will, if they are clean and smooth then i wont
good luck
Randy [email protected]
'78 Grand Prix all original 78k miles 301/auto
'82 Trans Am 5.0 and th350
'84 Caprice all original 99k 305 and 700r4
'85 K-20 350 and 700r4 and NP208 3.21 axles
'88 Toyota pickup 2wd 2.4L EFI and A43D AOD
