Old 05-26-2006, 01:15 AM
gracie01 gracie01 is offline
Send a message via Yahoo to gracie01
Angry What's wrong with my car?!?!?!?
The other day I drove my car and it drove just fine. I went to leave and I saw that the ground was wet under my car. I didn't think anything about it until I got in my car and turned it on and the coolent light came on. I put more coolent in but it still ran hot. It got to the point I had to turn off my A/C because smoke was coming out of the vents. I stopped my car today and turned it off and when I got out coolent was almost pouring out of the bottom. Is that my water pump or do I have a loose hose or a cracked radiator.
Old 05-26-2006, 09:29 AM
Cavalier2000's Avatar
Cavalier2000 Cavalier2000 is offline
Banned
Re: What's wrong with my car?!?!?!?
or hose were is the water comming from
Old 05-26-2006, 09:47 AM
Cold_Silence's Avatar
Cold_Silence Cold_Silence is offline
Send a message via AIM to Cold_Silence Send a message via MSN to Cold_Silence
Hmm thats pretty bad, smoke pouring from the vents? You must have had 0 coolant, there must be a bigger leak, feel the hoses to see if they are wet, and look at the water pump. Im fighting a coolant problem right now also but it doesent sound as bad as yours, good luck!
The New Ride!! 2002 Cavalier Coupe..
Originally Posted by noshun
It's a lovely 2200, but got about as much poke as my grandma with no fingers.
www.cleanstartsolutions.com
Old 05-26-2006, 10:51 AM
jerseycavyz24 jerseycavyz24 is offline
Yea i just fixed my coolant problem, i had a hole in my resivior, but urs seems to be a lot worse, def. sounds like a hose problem. Fill your car with coolant and let it run, and see where its coming from.
www.handsdownnj.com
Old 05-26-2006, 02:33 PM
Lances133's Avatar
Lances133 Lances133 is offline
Send a message via AIM to Lances133
Don't rule out the water pump.
Old 05-28-2006, 07:52 PM
Current Resident Current Resident is offline
the most likelt thing with steam coming from the vents is the heater core which by the way is a common problem with 95-2005 cavs
Old 05-31-2006, 08:35 PM
carcrazy88 carcrazy88 is offline
its def ur heater core-i had the same exact problem with my 94 grand am-one day it just started pouring coolant-and when i ran the a/c smoke came pouring in-so id definitly get a new heater core asap!
Old 06-08-2006, 09:06 AM
It was my heater core and not the water pump. My car is all good now!!!
