Old 05-25-2006, 08:53 PM
trixareforme trixareforme is offline
is this amp to much for these subs ?
i have 2 kicker 10" compvr subwoofers and i was wondering if a PowerAcoustik OV2-820 Gothic Series 2-Channel Amplifier would work with them ? or would it just blow um ?
any advice would be helpful, thanks a lot
Old 05-26-2006, 06:51 PM
RickwithaTbird's Avatar
RickwithaTbird RickwithaTbird is offline
Send a message via AIM to RickwithaTbird Send a message via MSN to RickwithaTbird Send a message via Yahoo to RickwithaTbird
Re: can subs work with this amp
what are the specs on the amp and speakers
R.I.P.: My Thunderbird "Ricks 96".. 2/08/96 - 1/14/05.
Old 05-26-2006, 08:09 PM
power acoustik amp ;
Features Bridged Max: 820 Watts, Mono RMS: 460 Watts, 180W x 2 RMS @ 4 Ohms, 230W x 2 RMS @ 2 Ohms
2 10" kicker subs;
Outer Frame Diameter: 10 11/16"
4ohms Nominal Impedance
Power Handling:600W Peak/300W RMS
Sensitivity:SPLo dB @ 1W, 1m 85.5
Effective Frequency Range: Hz 25-500
Mounting Depth: 5 7/16"
Hole Cut-Out Diameter: 9 1/4"
Equivalent Volume: 1.42Vas
43.23oz Magnet
Old 05-26-2006, 09:19 PM
The amp is not strong enough, really. It would do the job, but you need more power for those speakers.
Old 05-26-2006, 09:49 PM
how many watts would u suggest? and thanks a lot by the way for ur help
Old 05-30-2006, 12:37 PM
bjboertje's Avatar
bjboertje bjboertje is offline
a 2 channel that is rated for 300x2 rms @ 4 ohms.
or a mono rated at 600 rms @ 2 ohms.
2001 Ford ZX-2
Alpine CDA-9855
SAX 100.4
Rainbow CMX 265 front stage
Stock 5X7 rear fill
Hifonics BX1505D
TC-5200
