Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 05-25-2006, 08:40 PM
EagleTalon 91 EagleTalon 91 is offline
91 talon overheating dont know y
i have flushed radiator i have new thermostat all fans work y is it over heating nothin leak that i see . will the heat shield help the car over heat help me please fix this stupid problem
Old 05-25-2006, 09:03 PM
corning_d3 corning_d3 is offline
Send a message via Yahoo to corning_d3
Re: 91 talon overheating dont know y
Heat shield? Where?
2007 Certified DaimlerChrysler Service Technician...
True blue GM at heart.
Old 05-25-2006, 11:17 PM
ned032002's Avatar
ned032002 ned032002 is offline
When you turn on your heater do you get a heavy smell of antifreeze? If so then consider the heater core, if this gets clogged then fluid can't circulate causing an over heating problem, this happened in my spirit last winter.
Old 05-25-2006, 11:39 PM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
Have you filled it up with antifreeze? You're running a 50/50 mix right? Start it up and let it run while you fill it up.
95 Talon TSI AWD
97 Eclipse GST
Old 05-25-2006, 11:40 PM
Thor06's Avatar
Thor06 Thor06 is offline
Jizzed In My Pants
Could be a blown head gasket. Rev it and have a friend watch the exhaust. If theres any white smoke then its the hg.
Build on hold until I get a good paying job, either in school or once I get out. At that time a full tear down and complete rebuild should be in order.
The Purple People Eater will ride again... January 2011 can't come soon enough.
Old 05-26-2006, 12:22 AM
Thor, unless he see's a drop in his coolant level, I don't think a HG would cause overheating. And if the coolant did drop, the fill light would come on.
Eagletalon91, are you seeing any drop in coolant?
EDIT: Aren't you the guy that's trying to sell your car for $3000?!?!? AND it doesn't run right?!? WTF?
95 Talon TSI AWD
97 Eclipse GST
Old 05-26-2006, 10:31 AM
SLoe's Avatar
SLoe SLoe is offline
Someone needs to write an overheating thread and sticky that bitch!
Things to check:
1. Radiator cap;it's cheap, and causes more problems than you can imagine.
2. Thermostat; also cheap
3. Flush, clean, and pressure test radiator and hoses (make sure they are on properly and not bent shut, or have holes). Also watch while the car is running to make sure there isn't a hose collapsing in on it's self.
4. Listen for knock; detonation causes overheating (cheap gas, improper timing, etc.).
5. Water pump.
6. Fans coming on at proper temp.
7.. Finally, Thor's favorite....blown HG. Look for drop in coolant level, white smoke, water in oil, and excessive pressure on the hoses.
I think that about covers it.....3 grand for an overheating car? :
96 GST 5 spd.......(R.I.P.) smashed by a fallen tree
2001 Camaro SS 6 speed goodness!
Old 05-26-2006, 04:56 PM
ITSME4G63 ITSME4G63 is offline
Send a message via Yahoo to ITSME4G63
you might have air in the coolign system, when you run your car, run it with the heater on, then after you turn it off and cooled down, take of the radiator cap and squeeze the rubber pipe which goes between the radiator and the thermostat housign to let air bubbles out, you can do vise versa too.
