Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Suburban
Old 05-25-2006, 07:36 PM
h2012 h2012 is offline
Angry 97 Suburban Rear A/C not cool
Does anyone know what would cause the rear A/C to blow warm to barely cool air. The front A/C blows cold. The compressor has a full charge. I think it might be a clogged orafice tube filter but I have no idea where it would be located for the rear air. Could anyone please let me know if my assumption is correct or if there is something else I should check. Thanks
Old 05-27-2006, 02:32 AM
NoEcm NoEcm is offline
Re: 97 Suburban Rear A/C not cool
Probably the rear expansion valve.
Look here:
http://www.acsource.net/acforum/
and use this as your search parameters:
suburban and expansion and valve
Old 05-28-2007, 03:49 PM
dangerous dangerous is offline
me too !!!!!!!! thanks - great link
Old 06-01-2007, 02:54 PM
acme1 acme1 is offline
Where is the expansion valve located on a 96 suburban and do I need to discharge the system before replacing it?
Old 07-22-2007, 06:51 PM
CalessaSSracer CalessaSSracer is offline
Were is the location?
Old 07-27-2007, 11:35 AM
grumpy5 grumpy5 is offline
Look at figaros post for his 99. It appears that even if your pressures are good you still may not have enough volume of freon to satisfy both systems. I added two cans to my 99 and my bro-in-laws 96 and they both started blowing colder in the front. I have since lost some of my coldness. Now I have to look for a leak. Hope this helps.
