Go Back   Automotive Forums Car Chat > Chrysler > Concorde
Old 05-25-2006, 05:31 PM
soar soar is offline
Concored problem. Help!
Hi,
My chrysler concorde 94, 3.5. at the very low rpm there is a vibration of the engine which is going away at 1000 rpm and more. 3 left plugs are dirty black, 3 right ones are in good condition. The car runs fine at all conditions accept this which apears at intersections. If somebody can help me please send an e-mail to [email protected]
Thank you,
Alex
Optional Information:
1994 Chrysler 3.5
Old 06-05-2006, 07:25 PM
windowpane windowpane is offline
Re: Concored problem. Help!
JMO
Clean, better yet, replace the plugs.
John
Old 06-05-2006, 09:04 PM
Originally Posted by windowpane
JMO
I did it immediatelly when took this car from my friend. I wrote about condition of old plugs. Unforunately, the problem stay without changing and with new plugs too..
Old 06-06-2006, 09:15 PM
wvmso wvmso is offline
I had the same problem with two of my plugs on the passenger side. It hesitated between 1100 - 1500 rpm. I replaced the plug wires and it now runs great. This was on my 94 LHS. It was well worth the $45 for plug wires. That was with a 15% discount at Advance.
Old 06-07-2006, 05:50 AM
Perhaps, you right! I will try to do it. Thank you very much
Old 06-20-2006, 10:38 AM
mariettabrophy mariettabrophy is offline
I Own And Auto Shop. I Have A 94 Chrysler Concorde 3.3. Came In With Check Engine Light Codes For Cam O2 Sensor And Crank Sensor. Replaced Them. Car Still Stalls And And Rpm Go Up And Down. I Also Put Car On Scope Had A Bad Coil Replaced Coil. Car Is Still Cutting Out And Stalling. I Checked All The Grounds And Even Replace Computer. Car Cuts Out When Temperture Gets Between 165 And 200 Degrees. Also Replace Temp Sensor. I Had The Car To The Dealers Spokane Chrysler Plymonth And The Could Not Find The Problem Either. Any Help On This!!!!!!!!!!!! Please
Old 06-20-2006, 10:41 AM
Old 06-24-2006, 09:57 PM
Bizzy102 Bizzy102 is offline
Check your timing..
