Go Back   Automotive Forums Car Chat > Ford > Crown Victoria
Old 05-25-2006, 05:19 PM
CADUEDU CADUEDU is offline
P 71 Crown Vic Cng
HI,I NEED MORE INFO ABOUT CROWN VIC. WITH CNG.I BOUGHT A CAR 1997 CROWN VIC.AND I DON'T HAVE ANY INFO ABOUT THE CAR.WHEN I'M DRIVING IN THE HIGHWAY I FEEL THAT THE CAR DOSEN'T HAVE ENOUGH POWER,LIKE SPARK PLUGS DONT MAKE FIRE ENOUGH.
THANK'S
Old 05-25-2006, 10:56 PM
yotermanic yotermanic is offline
Re: P 71 Crown Vic Cng
I would get it scanned, to begin with. I wouldn't be surprised to see a P0171/172 lean bank 1/bank 2 code, the PCV lines were bad about rotting out and causing huge vacuum leaks, I'd check them anyway because sometimes you'd be suprised to see how bad it can get before you get codes. Also, how many miles are on it? It may be time for a set of plugs. Another thing to check is the EGR ports, they're behind the throttle body and were bad about cloggin up on those cars, they don't usually cause problems while cruising but they did cause enough weird issues, I pop the four bolts out and check instead of scratching my head when I got a mind-thumper. Anyhow, good luck with it and let us know what you find.
Old 05-26-2006, 09:08 AM
ModMech's Avatar
ModMech ModMech is offline
The CNG cars have less power than the gasoline cars, so it is possible that what you feel is "normal".
CNG cars DO NOT have any issue with EGR ports, in fact that problem mostly ended with the '95 MY and the aluminum intakes manifolds.
Yes, a vacuum leak could easily contribute to low power because the MAF sensor does not "see" all the air entering the engine.
A regular tune-up with a spark-plug replacement is an excellant place to start. At the very least, EVERY sparkplug wire should be checked with an ohm-meter to see if they are good. Also should inspect the air filter, and replace if overly dirty.
Old 05-26-2006, 09:36 AM
Thank Very Much For Your Atention...
