Go Back   Automotive Forums Car Chat > Honda > Civic | CRX > '96-'00 Civic
Old 05-25-2006, 05:02 PM
bionictony's Avatar
bionictony bionictony is offline
Send a message via AIM to bionictony
where could i find the ecu fuse to see if it's blown?
i tried looking under the hood fuse box and under the dash fuse box and can't fine the ecu fuse. where is it?
Old 05-25-2006, 09:12 PM
superbluecivicsi superbluecivicsi is offline
AF - Advisor
Re: where could i find the ecu fuse to see if it's blown?
http://forums.clubsi.com/showflat.ph...87&an=0&page=0
99 [email protected] psi si- I voted for the Terminator for Gov.
95 HB- B16a2- SC34@12psi
WTB: USDM B16a2 or B16a3 complete short block. pm is the key.
FS: B series InlinePro cast mani, PnH RC 550s, and Hondata S2b. pm me.
Old 05-27-2006, 06:25 PM
Wischmaster's Avatar
Wischmaster Wischmaster is offline
Not exactly sure on your year, but typically it's located in the engine bay fuse box. In the upper left there is a 15A blue fuse usually labeled as "ECM." That's the fuse your looking for.
Old 05-28-2006, 01:49 AM
bionictony's Avatar
i finally found it. it wasn't labeled ecu or ecm fuse at all. it said back up fuse/radio... and there was a 10 amp fuse in there. it's supposed to be a 7.5 amp fuse in there. so i took it out and put in a 7.5 and hopefully it will allow me to pass the smog check. does it damage the ecm if there is a 10amp fuse in a 7.5 amp socket?
