Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Suburban
Old 05-25-2006, 05:29 PM
awacht01 awacht01 is offline
95 suburban remote keyless entry
hello,
i just baught my 95 suburban and they only had one remote so i baught 2 on ebay. i was just wondering if i could program them myself instead of going to the dealer. the owners manual only says go to the dealer
any help would be greatly appreciated
thanks- Alec
Old 06-12-2006, 11:39 PM
nmforplay nmforplay is offline
Re: 95 suburban remote keyless entry
1. Locate the Data Link Port. It is located under dash drivers side. Be sure you know which pins are 8 and 4.
(Notice port is wider on top row)
2. Make sure there are metal contact pins in terminals 8 and 4. Connect 8 to 4 with a suitable jumper wire (leave the jumper wire connected throughout the programming procedure). Make sure you know which terminals are 8 and 4. The vehicle will respond by locking and unlocking the doors to signify entering of programming mode.
3. Press and hold both the LOCK and UNLOCK buttons together on the first transmitter to be programmed. After about 15 seconds, the vehicle will respond by locking and unlocking the doors. Release the buttons on the transmitter.
4. Within one minute, repeat the previous step on the remaining transmitters to be programmed.
5. Remove jumper wire applied to the OBDII Port.
That should to it. Goodluck
Old 06-14-2006, 10:28 AM
idmetro idmetro is offline
Alec,
Welcome to the forum. One of the handiest features is the search, you'll frequently be able to find answers to your questions from reading previous posts. Here's another on programming your remote. Together with nmforplays instructions above you should be truly dangerous
http://www.automotiveforums.com/vbul...remote+program
