Go Back   Automotive Forums Car Chat > Motorcycles & Choppers > Street Bikes
Old 05-25-2006, 11:24 AM
joelwideqvist joelwideqvist is offline
ignition lines on Yamaha R1
hi
I'm building a scale model of a Yamaha R1 -98 but it hasn't got any ignition lines from the spark plugs. Does anyone here know where they would go if they were there? I guess they go into some box somewere but were exactly is that located? Any help would be must appreciated
best regards
Joel
Old 05-31-2006, 09:12 AM
jeffcoslacker's Avatar
jeffcoslacker jeffcoslacker is offline
Lactose the Intolerant
Re: ignition lines on Yamaha R1
Not sure on that bike, but in general ignition wires are run the shortest distance possible (because resistance increases with length of wire), and so the coils are generally mounted under the tank somewhere just above the engine. So the wires would come off the head, pair up and run up towrds the gas tank, and disappear under it.
You made three mistakes. First, you took the job. Second, you came light. A four man crew for me? F**king insulting. But the worst mistake you made...
...empty gun rack.
Old 05-31-2006, 09:21 AM
http://dsr.racer.net/engines/yamaha_yzfr1.htm
See if there's anything useful here....
...empty gun rack.
Old 05-31-2006, 09:44 AM
I looked through the PDF manuals, and the coil is mounted on a plate between the upper frame spars, directly above the engine cylinder head....
...empty gun rack.
